Gb: Brand New Z32 Afm's - $330.00 Each
  • Replies 117
Blitz, this may seem like a sil question, but is there any difference between the genuine Bosch item and a Nismo one?
The Bosch/Nissan Z32 AFM's are 80mm,where the Nismo/Tomei units are smaller in physical size, but still have increased voltage capabilities over the standard AFM - They are also significantly more expensive and tuners I have spoken to seem to prefer the standard type 80mm Z32 over the Nismo/Tomei type units.
Hope this helps
Payment made and email sent to Darron
Alan
Hi Alan, your payment has been confirmed and is on its way to you via express post (Ref: # SN0581246)
Cheers,
Nick
Received the AFM yesterday, damn quick delivery :ninja: Thanks mate.
Anyways anybody know the wire colour codes for a R34GTT e.g which ones signal, batt etc, gonna splice and hook up myself...
Your very welcome mate :ninja:
Payment made and email sent to Darron :ninja:
Gday Matt, your payment has been confirmed and is on its way to you via express post (Ref: # SN0581247)
Cheers,
Nick
CAn you hook these units up to a stock RB20DET and see a difference or will it be just a waste of time until i get my Power FC?
Thanks guys
You will need to wait until you have a Power FC :D
Woohoo! Received mine today! thanks mate! :D
Also does it matter if on one side of the mesh it's slightly dented? doesn't look too bad might be able to gently move it back in place.
Cheers again!
Received the AFM yesterday, damn quick delivery :D Thanks mate.
Hey AcoustiK, try this thread, might help you a bit! :yes:
http://www.skylinesaustralia.com/forums/in...howtopic=116520
Woohoo! Received mine today! thanks mate! ;)
Cheers again!
Hi Dave, glad to hear it arrived safely - The dent in the mesh wont be a problem, in some cases people remove the mesh all together.
Hey Blitz,
Just transfered the funds, and emailed Darron too.
Thanks
Hi Nikki, your payment has been confirmed and is on its way to you via express post (Ref: # SN0581250)
Cheers,
Nick
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
