Gb: Brand New Z32 Afm's - $330.00 Each
  • Replies 117
Blitz, this may seem like a sil question, but is there any difference between the genuine Bosch item and a Nismo one?
The Bosch/Nissan Z32 AFM's are 80mm,where the Nismo/Tomei units are smaller in physical size, but still have increased voltage capabilities over the standard AFM - They are also significantly more expensive and tuners I have spoken to seem to prefer the standard type 80mm Z32 over the Nismo/Tomei type units.
Hope this helps
Payment made and email sent to Darron
Alan
Hi Alan, your payment has been confirmed and is on its way to you via express post (Ref: # SN0581246)
Cheers,
Nick
Received the AFM yesterday, damn quick delivery :ninja: Thanks mate.
Anyways anybody know the wire colour codes for a R34GTT e.g which ones signal, batt etc, gonna splice and hook up myself...
Your very welcome mate :ninja:
Payment made and email sent to Darron :ninja:
Gday Matt, your payment has been confirmed and is on its way to you via express post (Ref: # SN0581247)
Cheers,
Nick
CAn you hook these units up to a stock RB20DET and see a difference or will it be just a waste of time until i get my Power FC?
Thanks guys
You will need to wait until you have a Power FC :D
Woohoo! Received mine today! thanks mate! :D
Also does it matter if on one side of the mesh it's slightly dented? doesn't look too bad might be able to gently move it back in place.
Cheers again!
Received the AFM yesterday, damn quick delivery :D Thanks mate.
Hey AcoustiK, try this thread, might help you a bit! :yes:
http://www.skylinesaustralia.com/forums/in...howtopic=116520
Woohoo! Received mine today! thanks mate! ;)
Cheers again!
Hi Dave, glad to hear it arrived safely - The dent in the mesh wont be a problem, in some cases people remove the mesh all together.
Hey Blitz,
Just transfered the funds, and emailed Darron too.
Thanks
Hi Nikki, your payment has been confirmed and is on its way to you via express post (Ref: # SN0581250)
Cheers,
Nick
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
