i cant give you a 100% answer, but im almost certain i seen one come up in the used cars before. either way u can get 32 Gts-t so i would be surprised if you couldnt get 33. although you only seem to be able to get 34 in GTR. oh well. even for the sake of one car, its a great game mate :happy:
yeah, this is what ive seen listed for GT4.
Nissan SKYLINE 1500Deluxe (S50D-1) 1963
Nissan SKYLINE 2000GT-B (S54A) 1967
Nissan SKYLINE 2000GT-R (KPGC110) 1973
Nissan SKYLINE GT-R (R32) 1989
Nissan SKYLINE GT-R (R32) 1991
Nissan SKYLINE GT-R (R33) 1995
Nissan SKYLINE GT-R (R33) 1996
Nissan SKYLINE GT-R (R33) 1997
Nissan SKYLINE GT-R (R34) 1999
Nissan SKYLINE GT-R (R34) 2000
Nissan SKYLINE GT-R M-spec (R34) 2001
Nissan SKYLINE GT-R M-spec Nur (R34) 2002
Nissan SKYLINE GT-R N1 (R32) 1991
Nissan SKYLINE GT-R N1 (R33) 1995
Nissan SKYLINE GT-R Special Color Midnight Purple II (R34) 1999
Nissan SKYLINE GT-R Special Color Midnight Purple III (R34) 2000
Nissan SKYLINE GT-R Vspec (R32) 1993
Nissan SKYLINE GT-R Vspec (R33) 1995
Nissan SKYLINE GT-R Vspec (R33) 1996
Nissan SKYLINE GT-R Vspec (R33) 1997
Nissan SKYLINE GT-R V-spec (R34) 1999
Nissan SKYLINE GT-R Vspec II (R32) 1994
Nissan SKYLINE GT-R V-spec II (R34) 2000
Nissan SKYLINE GT-R V-spec II N1 (R34) 2000
Nissan SKYLINE GT-R V-spec II Nur (R34) 2002
Nissan SKYLINE GT-R Vspec LM Limited (R33) 1996
Nissan SKYLINE GT-R Vspec N1 (R32) 1993
Nissan SKYLINE GT-R V-spec N1 (R34) 1999
Nissan SKYLINE GTS25 Type S (R32) 1991
Nissan SKYLINE GTS-R (R31) 1987
Nissan SKYLINE GTS-t Type M (R32) 1989
Nissan SKYLINE GTS-t Type M (R32) 1991
Nissan SKYLINE Hard Top 2000 RS-X Turbo C (R30) 1984
Nissan SKYLINE Hard Top 2000 Turbo RS (R30) 1983
Nissan SKYLINE Hard Top 2000GT-R (KPGC10) 1970
Nissan SKYLINE SEDAN 300GT 2001
Nissan SKYLINE SEDAN 350GT-8 2002
Nissan SKYLINE Sport Coupe (BLRA-3) 1962
no R33 GTST = :happy:
i guess i'll dig out my big ass old grey PS and Gt2, so i an drive MY car.
Why get a gts-t when there are all those GTR's :D.
becasue GTR's suck balls (joke)
I just like driving MY car in a video game, that is all.
oh, I pulled out my playstation, it no workey workey any more :D
but the GT2 disc still smells like burnt rubber!
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
