Various Car Stereo - Must Go
Selling a monster Cadence amp. 800X1WRMS at 4 ohms bridged. I had it running two 15's. End caps have been re-painted with pink 2pack but you can spray them any colour you like. Works perfectly $400 ono
NEW IN BOX! Linear Series 5.25" speakers. These are some really nice sounding midbass speakers. They are sold as an individual unit so you can pick and choose your own crossovers and tweeters. I also have some crossovers for sale that would suit these speakers. These have a really solid build quality compared to a lot of other brands. A bargain at $50.
NEW IN BOX! Linear Series 2 way crossovers. 200W power rating, 5.5khz crossover point, 12dB slope. Would suit the above speakers or else anyone wanting to make up their own splits. I have 2 sets. $30 per set.
Phoenix Gold 15" subs in custom MDF box. These subs are Dual Voice Coil which means they can be wired as either 2 or 8 ohms individually, or paralleled together to create a 4 ohm load for your amp. They handle 350WRMS each and have a Glass-aramide cone material. The box was made to suit a Nissan Pulsar N13 Hatch but also fits AU/BA/BF wagons perfectly to the angle of the seats/cargo barrier!! I made 145+dB with these subs. $250firm for the lot (compare that to what you can get at JB for the same price!!)
OR TAKE EVERYTHING FOR $650 FIRM!
I can email more pics on request.
Installation is available for any of these items if needed
I am open to genuine offers.
I'm in victoria, postage can be arranged for the amp and speakers if interstate.
Call 0438 235 177 or leave a PM.
Kat
Edited by Ricey
https://www.sau.com.au/forums/topic/130381-various-car-stereo-must-go/
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
