I've fitted a set of R33 GTR brembo's to a R33 GTS-T before and was a straight boltup pretty much and I imagine the mounting brackets are exactly the same to the R32 GTR. All that was needed for the conversion was larger rotors and the original brakes lines from the 33 GTR. If the lines weren't included they can be done up easily at most brake joints. Plus you might as well upgrade to braided lines if your going to the trouble of doing so. Braided lines made in Australia are legal as well, as far as I know.
they fit, (discs and calipers) you need to modify the brembos slightly to fit the stock 16inch wheels. a
15mm bolt on spacer is needed.
good front track increase too :huh:
about 3mm needs to be linished off the calipers outer diameter (the part closest to the rim) as its not flat. this is so the wheel can spin... etc etc
apart fom that its very straight forward :)
    • EMU Classic. For what I need it to do I see no reason to upgrade. Link and Haltech would both cost an extra chunk of money for a lot of unutilized features
