Hey boys
I bought this not too long ago but couldnt find a decent manifold for my rx7..
Its brand new, never fitted, never run, still got plastic seals n all...
So here it is, opened the box just to take pics, they are designed and engineered in the US by "HyperGear". This is NOT a cheap shit made in china, but korean built.
As it is brand new it still retains it 30,000KM or 6 month warranty.
This thing on a skyline should be nothing but awsome
Compressor wheel:
Inducer: 76.2 mm
Exducer: 56.8 mm
Turbine wheel:
Inducer: 74.2
Exducer: 56.6
Manifold flange: T3x
A/R: 0.58
Developed for: RB20DET, RB25DET, RB30DET engines. This Turbo is capable for 450HP application.
This is a high end performance turbo. The turbo responds is from about 3000RPM depends on engine type. This turbo is designed for track and drag racing. The max recommended boost out put is no higher then 25PSI.
10PSI actuator, Rear Dump pipe flange and hollow screw.
Also got a 3inch Stainless steel dump pipe for $50.
Im after $570 i got it for $620 3 months ago.
Pm or email [email protected]
Cheers
This is a dyno chat was from a mates car. Its a RB20DET Nissan cefiro pulling 214KW at 1 bar boost.. Just imagain how it will run on a rb30
Another mate of mine got 263.2kws out of this thing on a rb25, his had it for 12,000kms we took it out when we put in a new dump pipe, there was no shaft play what-so-ever.
Cheers
on an rb25 are there any modifications required to fit this? like modified oil or cooler lines & will it fit on the stock manifold?
mite be interested in a few weeks if still for sale ill let u no. how much to send to sydney?
its around $20 all over aus
fits right onto stock manifold, u just need a braied oil lines, a dump pipe n 3inch stainless stell elblow
They look very very similar to Garretts TA34-1 turbocharger . Same specs but Garretts actually has "Garrett" cast into the comp cover and their turbine housing is dimensionally the same .
The term TA34 is the correct description of what many call T3/T4 hybrid though the turbine is TB31/TA34 not T3 . The compressor in those things is just a small trim TO4E wheel in a .50AR ratio TO4E cover . They are bush bearing and was told ages ago not a bad thing on an RB20 .
Fred from Turbologic in Port Kembla (near Woolongong) has been selling the Garret version for ages .
They were not developed specifically for Skylines .
About the best feature of these things is the T3 flanged integral gate exhaust housing in .58 AR ratio and with its native turbine series works well on 2-2.5L petrol engines . Not my choise of compressor for that turbine but hey they were developed in the dinosaur days .
Not bad if you can get the genuine one cheap , the other one - who knows . Price check .
Cheers A .
These are made 100% by Hypergear, they dont carry any parts made by or labled "garret"
These were engineered in the US, alough they are based on ur avarege t04e design, they have been made to spool up quicker...
Heres some ppl that have these turbos, Dr. Drift, Drift line, JSA performance, Holford motors, and various performance shops around Australia, MR 1JZ, WildR33, and even Sam from Dr.Drift at his own drifting car.
so is u take that other rear clamp off will it bolt straight on to ur existing dump? how much would it cost to fit the turbo all up?
no you need a new dump as the rear flange is v band...and I fitted mine on a stock manifold last night, requires a small amount of grinding but nothing major
Closed.
It has come to our attention that you are on-selling parts from Hypergear, this is not on.
Deliberately misleading moderators and attempting to skate around the rules will not be tolerated on SAU
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
    • Ah coolant overflow, previous discussions make way more sense now lol.
