Ok, my r32 gtst is overheating like a cat on heat now, and i just went down to a radiator specialist. turns out the clutch fan can freely move when the engine is turned off, so he reckons its stuffed. It still does spin though when the car is on, but it obviously isnt getting enough airflow.
The problem is now, trying to find a working replacement clutch fan. its bloody hard finding one for a rb20. do the rb26 or rb25 ones fit up ok? would i just need the hub?
The other option i could go is a thermofan i spose, but im worried about hooking up a controller. dunno what to do about all this :P
https://www.sau.com.au/forums/topic/130870-clutch-fan-problems/
are you for real..
take it to someone who's heard of a clutch fan!!!
when cold, the fan is driven by a viscous coupling so it spins, but not with any force. it will move a nominal amount of air through the radiator but if the car heats up the clutch should lock, and then the fan is driven directly proportional to engine revs (you should probably be able to hear it, although the difference is less with more modern cars. My R31 sounded like a falcadore when the fan kicked in, R33s are much quieter owing to better technology in the shape of the fan blades).
If your car is overheating these are the possibilities:
1) Shagged water pump
2) Blocked thermostat
3) Blocked radiator
4) Clutch fan not locking up properly.
Does it overheat on cruise or just when stationary?
it overheats on cruise.
when i brang it down to the rad guy this morning, the system was pretty warm/hot. the needle on my temp gauge was halfway up.
i had the engine replaced 3 months ago by mercury after a *ahem incident*, and it overheated on day 1 i got it back. took it back to them, had it pressure tested and it came back fine. they put it down to a bubble in the system. then for 2 more months it only overheated once more, so i put it down to a bubble in the system too (i bled and flushed it after it the 2nd time).
However the last 2 weeks its just been getting worse and worse, where its at the stage now whenever i go for a 20+ min drive it will overheat and i have to turn the heater on full to keep it at normal temps :mad:
also i just rang around some places, 1 wrecker wants $175 for a clutch fan hub, and moorooka nissan said there are no hubs in australia, but can get one from japan for $423 :stupid: not really sure if the 2nd hand price is fair or not
another question...is the sr20 hub a direct replacement, or a rb25/26?
Edited by flagger
3) Blocked radiator
I would be looking at Option numbers 2 or 3 first before changing the clutchfan.
If you have no idea how old the radiator is, and it looks a little tired, chances are it's due for a cleanout. Take it to a decent radiator place and have them do a proper cleanout and flush on it, none of this jam a hose through it and hope its ok :laugh:
Otherwise, its possible you have a sticky thermostat, which could explain why its only overheating every now and then. Occasionally frees up and runs fine, but sticks most of the time...
Possibly then look at clutch fan...
Does it only overheat when stationary or at speeds below say 60, once on the highway it cools down? Suspect clutch fans, and blocked radiators seem to show similiar symptoms, so can be hard to judge.
it doesnt overheat when idle. usually overheats when i load the engine up, say by boosting or going up a hill for a short while. ie. last tuesday night, i was going down ipswich motorway, temp was fine, then i gunned it in fourth for about 20 seconds, and the temp guage was 3/4 the way up. when i pulled over, the coolant was boiling :laugh:
thing is im getting a kit put on this monday, so i wont be getting the car back till tuesday. so i cant do much till later in the week. i guess ill get a radiator place to rod clean it out and replace the thermostat. would radiator places carry the right thermostat for a rb20det?
cheers for the help so far
Edited by flagger
i agree ^
I replaced the clutch fan hub on my car with a craig davies hub i bought from Sprint auto. It had on the box Skyline r32, r33 and vl holden (rb30et) It cost $130 @ trade price. Just a heads up incase...Flush the rad (including heater box core) + system, replace thermostat and cap, bleed system. If that fails replace clutch...let us know how u go:)
well ive already flushed and treated the system (including core). what im gonna do is drop it into a radiator place sometime this week, get them to rod clean the radiator and change the thermostat and see how it goes. if theres still probs then its time for a new hub.
good to know the rb30 and rb25 hub fits on fine too :rofl:
flagger, I am not really certain if the part numbers are identical nor the temps they both open at but I know that they both fit.
If you like I can find out for certain tomorrow, as I do have a contact at Nissan who will suss it out for me. From memory though, the rb30 thermostat opens at 76.5 degrees or there abouts. No difference in thermostat as far as i am aware between rb30e and rb30et, so i could not see a problem running the 30 thermo on a 20 etc.
No worries, will post up tomorrow with some more information.
edit* just done some quick searching on these forums and it appears rb30 and rb20 thermostats are identical heat range, being 76.5 degrees.
Part number for the rb20det unit from an R32 is 21200-42L05 apparently..
I can confirm a part number for the rb30 unit, i do have some in stock at work as far as i know. Can check a price for you and let you know.
Post back tomorrow
ok, just as a follow, i took my car in today to cairncross radiators at albion. turns out the radiator was 90% blocked. since they had already pulled out the old radiator and removed the endtanks, I just got them to install a new radiator (koyo 25mm alloy). Apparently ive been running without a thermostat as well, only the housing was there. they couldnt source the right thermo (they tried to fit a rb30 one in but couldnt), so im still currently thermostatless.
so i got it back, and gave it a bit of a thrash on the way home, and the stock temp gauge stayed in the centre (took a while to warm up of course). so it appears to be ok. dunno if i can be bothered sourcing a thermostat.
thanks for all your help guys. :D
Edited by flagger
u could be using more fuel if u dont run a thermostat.
*my own opinion*
Doesnt the ecu use the temp sensor to decide when the cars warmed up, and puts in less fuel??
*flame away* but thats my thoughts, as the car will take longer to warm up without the thermostat.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
