Firstly greetings to all I'm sure this will be the first of many posts here.
I've gone and bought myself a little S1 Stagea and following the usual time delay from the Japanese docks to here my car has finally arrived. :) but I am going to need an exhaust for registration purposes.
It has a DAYZ rear bar setup on it and I was wondering if a S2 exhaust will fit into a DAYZ rear bar because, if I'm not mistaken, S2's have a twin tailpipe setup?
Any info would be appreciated as I haven't seen the car in the flesh yet and therefore can't measure anything, but it's ohhh sooo close now, I can't wait to give it's first wash and push all the buttons for the first time open the sunrooves etc, etc. :D
Hope to maybe see all you Sydneysiders on the next cruise.
Rhys.
https://www.sau.com.au/forums/topic/131008-hello-help/
Rhys.
Does the car have an AFM echaust? or it doesnt have one? If you only need for the complianc purposes where are you located at? Which compliance center are you gonna use?
https://www.sau.com.au/forums/topic/131008-hello-help/#findComment-2423503
what's an AFM exhaust?
also the exhausts are the same from the turbo back, i'm not sure if there's a different flange for the NEO turbo though.
Yes, series 2 have twin tail pipes
The R34 Neo turbo flange is the same as the series 1 R33 turbo
Series 2 Stagea need 2 cat's
One goes in the standard location and another smaller ones fits in the dump pipe section.
https://www.sau.com.au/forums/topic/131008-hello-help/#findComment-2423811
Thanks Ska
Stasis: It does have an aftermarket exhaust on it at the moment that was re-fitted after compliance, the rear muffler has been cut off so that a repair can be done to the rear bar that some Japanese genuis :D decided to mutilate in order to make an incorrect exhaust fit the vehicle.
Imagine this image with the rear muffler removed so it does not interfere with the bar that has since been repaired:
file://localhost/Users/neil/Desktop/211.jpg
My location is in Sydney but this is something I could do on the hoist at work. So I was wondering if by chance I come accross a S2 std cat back would the twin tailpipe muffler fit? (or even better if I can find a S1 cat back that I know 100% will fit) Just so the car will pass EPA/DBA requirements etc so I can get number plates on the car and it doesn't have to be tilt-trayed everywhere costing me coin.
Any suggestions or anyone willing to lend/rent me an exhaust they have lying around would be greatly appreciated, I'll even cover it in black pressure pack for you so you can sell it easier when I bring it back as unmarked as you lent it to me :D
Rhys.
https://www.sau.com.au/forums/topic/131008-hello-help/#findComment-2423838
Thanks Ska
Rhys.
i presume your ride is a RS4?
https://www.sau.com.au/forums/topic/131008-hello-help/#findComment-2423984
sorry cant help you then
stasis: thanks anyway mate :D
I still don't know if a S2 rear muffler's dual pipes will fit under my bar? And will that dual muffler setup that darrinspencer mentioned present any mounting drama's?
If anyone can help, I'll say thank you?? :D
https://www.sau.com.au/forums/topic/131008-hello-help/#findComment-2424036
Stasis: Sorry mate, I'll try and explain this a bit better, car turns up from Japan with exhaust as seen in the photo, exhaust is removed, standard exhaust (belonging to compliance shop fitted) car passes compliance, aftermarket exhaust refitted, rear muffler had to be cut off so that the rear bar could be repaired. (see pic and imagine what it looks like with repaired lower bar and no muffler now and that's what I'll be dealing with when my car turns up)
So now I have an extremely noisy exhaust with no rear muffler on a car that needs to pass a blue slip. Once that's done and the car's registered
Sorry if I confused you mate, I have a roundabout way of explaining things that usually makes sense only to me. :D
https://www.sau.com.au/forums/topic/131008-hello-help/#findComment-2424079
i think mounting wise they would be the same, i dont see why they would have changed the mounting brackets.
the onyl difference i see is the twin tips being an issue as the rear bar is moulded for a single tip.
Bingo!!
wagonwheels i have a standard S2 exhaust sitting in my garage going cheap if you want it. if you want just the cat back then let me know and come around.
i am located in sydney.
Really? If it fits mate it's as good as gone pending the amount of coin you want for it. I don't want to waste your time and mine though Wolverine so I need to establish if it will fit. (I don't want to have to cut the rear bar to make it fit :D
https://www.sau.com.au/forums/topic/131008-hello-help/#findComment-2424090
if it fits i'm sure we can agree on a fair price.
one teeny weeny problem, I don't have the car yet, I kinda wanted to have the exhaust at work so that when the car get's dropped off I can throw it on the hoist, change the exhaust, get the car registed and then drive my new baby all night until I feel a microsleep coming on, crawl into the back and see how much more comfy she is than the dog kennel for future nights when I upset the misus.
I'll keep you in mind mate cheers.
I think I might post a WTB in for sale section for a S1 first though, at least I know it won't give me any drama's
https://www.sau.com.au/forums/topic/131008-hello-help/#findComment-2424111
if you want to take it and consider any payment a refundable deposit (in the event it doesn't fit) that's cool with me.
you Stagea boy's are mighty friendly I've been finding out today, I've put a WTB in the Stageafieds for a S1 exhaust but if I don't find one mate I'll take up your offer if I need to go the S2 direction, providing you haven't sold it by then that is???
https://www.sau.com.au/forums/topic/131008-hello-help/#findComment-2424127
    • All trim back in wired running driving. Few things to follow up on but not far off the return to the road. att.6HN4wP38LTIOISkhA8eACoBFqzfgQMahZPLA8ut0pqE.mp4 att.w2q0ux2PGuqgQTj2Os13cNHQtqcSEcCAhD_CAXy_IQM.mp4
    • The trouble with phone apps is that they really do not know the sensitivity of the mic on each specific phone, whether there is some sort of cover or skin that can change that, etc etc. So the readings off them are not calibrated. You certainly couldn't be sure that you were even within 3 dB. I have the same app on two (actually more than that) different phones/tablets and the readings in the same room at the same time are never the same. I don't mind the apps - they are as useful as a dyno - if you're testing for delta from thing1 to thing2. But not to try to generate some sort of absolute value.
    • I'm gonna use the "Sound Meter" app from the Google Play Store and as close as I can bother to these procedures: 4. TEST METHOD FOR ALL VEHICLES EXCEPT PRE ADR83 IN-SERVICE GOODS VEHICLES AND OMNIBUSES 4.1 Microphone position 4.1.1 The microphone shall be directed towards the orifice of the exhaust outlet and shall be supported by a tripod or similar device not providing excessive acoustic reflection. The general requirements for positioning microphones are shown in the Appendix. 4.1.2 The nominal axis of maximum sensitivity of the microphone shall be substantially parallel to the test site surface and shall make an angle of 45 degrees ±10 degrees with the principal direction of gas flow from the exhaust. 4.1.3 In selecting the 45 degree alignment from the outlet of a motor vehicle fitted with two or more outlets, only the angle resulting in the microphone being farthest from any other outlet must be used. National Stationary Exhaust Noise Test Procedures for In-Service Motor Vehicles Page 3 4.1.4 The height of the microphone above the test site surface shall be equal to that of the orifice of the exhaust outlet ±25mm but shall not be less than 200mm above the test site surface. 4.1.5 The distance of the microphone from the exhaust outlet orifice shall be 500mm±25mm. 4.1.6 [Relates to vertical exhaust outlets] 4.1.7 For vehicles fitted with one exhaust outlet the microphone shall be placed so that the greatest possible distance is achieved between it and the vehicle. 4.1.8 [Relates to multi exhaust outlets] 4.1.9 [Relates to multi exhaust outlets] TLDR: 200mm off ground 45 degree angle relative to exhaust flow 500mm from tailpipe exit. (I probably won't use a tripod) Here's a photo, cause I read the instructions wrong myself.
    • No ABS, no TCS, no airbags, no cruise control, no lane departure assist, no emergency brake assist, no orange lights in the mirrors (continuously annoying me in multi-lane traffic), no stupid rear view camera. I am the one responsible for where my car goes and how it does it.
    • Cheapest Jaycar one is only $65.
