Guest MFX_R33
Pawel,
You could possibly sell the engine off eaiser than the whole car (with a swap for a stock engine). I would consider this in a couple of months. As I know alot of people get attached to their cars and want to improve their own, without going through the trouble of selling theirs and buying yours.
Just a suggestion, could be a quicker option in the long run????
Jeff.
  • Replies 85
1992, 5 speed, alpine cd player, might be jacked up (not sure) 83,000 kay's, sunraysia wheels, sports exhaust, and it's white and a soft top ( J top means soft top) and is an import.
whats your email, and i'll scan some pics as soon as I can
well i doubt you would be interested in mine.. but
1993 2.4 with recaro interior and auto
90,000kms
Widebody, rear spoiler, nudge bar & sunroof
very simple clarion sound system
3litre head
turbo smart boost controller
autometer boost gauge
custom k&n cold air intake right into turbo
1000CCA high performance dry cell battery
coming in next 4 weeks
35% all round tinting
r33 top mount intercooler
let me know anyway.
fuel is very bad becuase I floor it all the time... but driving from qld to vic.. i was getting 500km per 60l but that was doing 130km the whole time... at 3300 rpm, where 100km/h is only 2000rpm.
rust not a problem at all.
when your buying if its a 3ltr u wont have a problem, but a 2.4 make sure its had head work. Also heaps of them are accident damage. Umm.. also, diesels last forever but cost heaps to maintain, so make you get a well maintained one or you will be in for big bucks.
Since having mine the main expense was the head.. then after that i had most belts and hoses replaced just due to age. Also a CV joint boot needed replacing but they break when something from the road flies up and hits them. Other than that I got a well maintained 2.4 with full recaro interior and it has been great and only costs $550 a year to insure (and im only 19).
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
