Guest MFX_R33
Pawel,
You could possibly sell the engine off eaiser than the whole car (with a swap for a stock engine). I would consider this in a couple of months. As I know alot of people get attached to their cars and want to improve their own, without going through the trouble of selling theirs and buying yours.
Just a suggestion, could be a quicker option in the long run????
Jeff.
  • Replies 85
1992, 5 speed, alpine cd player, might be jacked up (not sure) 83,000 kay's, sunraysia wheels, sports exhaust, and it's white and a soft top ( J top means soft top) and is an import.
whats your email, and i'll scan some pics as soon as I can
well i doubt you would be interested in mine.. but
1993 2.4 with recaro interior and auto
90,000kms
Widebody, rear spoiler, nudge bar & sunroof
very simple clarion sound system
3litre head
turbo smart boost controller
autometer boost gauge
custom k&n cold air intake right into turbo
1000CCA high performance dry cell battery
coming in next 4 weeks
35% all round tinting
r33 top mount intercooler
let me know anyway.
fuel is very bad becuase I floor it all the time... but driving from qld to vic.. i was getting 500km per 60l but that was doing 130km the whole time... at 3300 rpm, where 100km/h is only 2000rpm.
rust not a problem at all.
when your buying if its a 3ltr u wont have a problem, but a 2.4 make sure its had head work. Also heaps of them are accident damage. Umm.. also, diesels last forever but cost heaps to maintain, so make you get a well maintained one or you will be in for big bucks.
Since having mine the main expense was the head.. then after that i had most belts and hoses replaced just due to age. Also a CV joint boot needed replacing but they break when something from the road flies up and hits them. Other than that I got a well maintained 2.4 with full recaro interior and it has been great and only costs $550 a year to insure (and im only 19).
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
