Guest MFX_R33
Pawel,
You could possibly sell the engine off eaiser than the whole car (with a swap for a stock engine). I would consider this in a couple of months. As I know alot of people get attached to their cars and want to improve their own, without going through the trouble of selling theirs and buying yours.
Just a suggestion, could be a quicker option in the long run????
Jeff.
  • Replies 85
1992, 5 speed, alpine cd player, might be jacked up (not sure) 83,000 kay's, sunraysia wheels, sports exhaust, and it's white and a soft top ( J top means soft top) and is an import.
whats your email, and i'll scan some pics as soon as I can
well i doubt you would be interested in mine.. but
1993 2.4 with recaro interior and auto
90,000kms
Widebody, rear spoiler, nudge bar & sunroof
very simple clarion sound system
3litre head
turbo smart boost controller
autometer boost gauge
custom k&n cold air intake right into turbo
1000CCA high performance dry cell battery
coming in next 4 weeks
35% all round tinting
r33 top mount intercooler
let me know anyway.
fuel is very bad becuase I floor it all the time... but driving from qld to vic.. i was getting 500km per 60l but that was doing 130km the whole time... at 3300 rpm, where 100km/h is only 2000rpm.
rust not a problem at all.
when your buying if its a 3ltr u wont have a problem, but a 2.4 make sure its had head work. Also heaps of them are accident damage. Umm.. also, diesels last forever but cost heaps to maintain, so make you get a well maintained one or you will be in for big bucks.
Since having mine the main expense was the head.. then after that i had most belts and hoses replaced just due to age. Also a CV joint boot needed replacing but they break when something from the road flies up and hits them. Other than that I got a well maintained 2.4 with full recaro interior and it has been great and only costs $550 a year to insure (and im only 19).
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
