Guest pawel
I realise why I hate selling cars I have advertised my car in the Trading Post and I got a few calls. Already had one tyre kicker his main concern was does the car break traction and goes sideways well I said generally my car with 300rwkw or any car with that power generally will break traction if you put your foot down.
  • Replies 85
it's tough isn't it.
pm me your mobile if you don't want to post it here cause i got a mate that's in the market. i told him about your car and he was interested but the price originally was too much for him. i'm thinking if he sees your car he might be willing to stretch his budget.
Pawel have you considered, running your beast at Eastern Creek (Drags).
This way you can market the true potential of your car without the tyre kickers.
A friend ran his white R33 GTST 6 months ago - 11 Flat & was inundated with serious offers.
Too many people want to know drag times so I said stuff it and now preparing for the strip. My mechanic will drive because he holds could records and I would stuff up and get **** times. Plus with slicks we should get good times. I will also get updated Dyno Papers done.
Finally got my car back from the mechanics it now has new gaskets copper the head now has been O-Ringed the car is was dynoed last Thursday it got to 280 RWKW at 120kph 900nm of torque at 5,500rpm in fourth gear before it lost traction on the dyno even with 2 guys in the back boot. Also my body kit is complete new front Nismo 400r bar with GTR rear wing. The whole car looks like a proper show car now. Final price now $33000 with $4000 pioneer system includes 5 channel kicker amp competion boston acoustics speakers splits in the front and bostons in the rear. JL Audio 12inch Subwoofer also. With a $1600 Pioneer head unit. $31000 no Stereo. More Pics coming very soon of whole car and engine bay. any questions call me 0414 253 876.
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
