Selling my rims which will be available in approximately the next week (27th August-ish)
Rays Engineering Nismo LM-GT2's in 17x8 (+35 offset) and 17x9 (+38 offset) off an R33 GTS-t.
Very good condition with Kumho tyres all round (235 front 255 rear). Camber wear on the inside rears is a bit higher than the rest, but overall I would say about 50-60% all round. Done 17,000kms.
Very minor gutter rash on one of the rims, but only noticable on close inspection. The Nismo stickers have seem better days but the rims themself apart from needing a good clean are in excellent nik.
Inspection in Perth welcome, and closer photo's available on request for those elsewhere.
$1200 plus postage.
I'm interested, but can you get the exact offset for both the fronts and rears please? If it's not printed on the rim, then it's quite easy to measure like this:
http://www.rsracing.com/tech-wheel.html
Edited by orbitor
the rears are definately +38, and the front i'm 90% sure are the same, but both of the stickers are behind the calipers so it is hard to see in the dark.
i will confirm in the morning, but if it isn't 38 then it is 36.
front offset is 35.
fills out the guards nicely, should fit exactly the same on R32, R34, S14 and S15.
bugger, looking for a lower offset for my s13 :D Thanks for looking anyway.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
