Selling my rims which will be available in approximately the next week (27th August-ish)
Rays Engineering Nismo LM-GT2's in 17x8 (+35 offset) and 17x9 (+38 offset) off an R33 GTS-t.
Very good condition with Kumho tyres all round (235 front 255 rear). Camber wear on the inside rears is a bit higher than the rest, but overall I would say about 50-60% all round. Done 17,000kms.
Very minor gutter rash on one of the rims, but only noticable on close inspection. The Nismo stickers have seem better days but the rims themself apart from needing a good clean are in excellent nik.
Inspection in Perth welcome, and closer photo's available on request for those elsewhere.
$1200 plus postage.
I'm interested, but can you get the exact offset for both the fronts and rears please? If it's not printed on the rim, then it's quite easy to measure like this:
http://www.rsracing.com/tech-wheel.html
Edited by orbitor
the rears are definately +38, and the front i'm 90% sure are the same, but both of the stickers are behind the calipers so it is hard to see in the dark.
i will confirm in the morning, but if it isn't 38 then it is 36.
front offset is 35.
fills out the guards nicely, should fit exactly the same on R32, R34, S14 and S15.
bugger, looking for a lower offset for my s13 :D Thanks for looking anyway.
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
