Does anyone know where to buy Nismo floor mats?
Nengun can not supply them anymore for the R33 GTS-T they are a discontinued line.
The only choice i can find is from ebay at $315 per set.
Does anyone know where I can buy them ? either online or in Sydney cheaper than this?
https://www.sau.com.au/forums/topic/131200-nismo-floor-mats/
i've been looking for the same thing. I found those ones on ebay but daayum thats a pretty penny for some mats with a logo. like buying gucci toilet paper or something.
warren thanks for the link to these other mats - do you have a pic of them in your car?
click here for the R33 mats
Heres a pic too:
i have no pics on my computer.. i could take some, but that would require effort! ha ha
no i'll try and remember to take some pics tonight...
seriously the accessories online ones (same as pictured above) are great quality and a serious bargain!
I was looking at those, but they dont have a strip that goes across the middle at the back like the stock ones do...
I just ordered a set for an R32 GTR from http://www.greenline.jp was about $260 something
Ive writen to greenline to confirm shipping/orders three times before and they never reply, so i always end up buying from nengun instead ....frustrating, but i suppose they would prob. get lots of emails every day
I bought a set off the eBay seller (Nate tune). They are genuine items. That's what they cost. You are unlikely to import a set yourself that cheap as he buys them and ships them in a container.
Unfortunately Nismo don't make GTS-t mats anymore, the GTR mats fit up fine except for the driver's one which has a missing spot where the transfer case bulge should be. Still good though.
Cheers for that
I was just keen to bring them down a tad, i know they are expensive i was looking to order from nengun (think they were $220), ive been ordering lots of stuff from then so it wouldnt have added much for shipping.
$300 + $15 delivery is pretty dear for floor mats, but i dont want cheap ones so i think ill just have to fork out for it, they are 1/3 a set of cams or a metal head gasket though :D
Nate tune said he is looking to set up as a trader, maybe group buy?
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
