All parts are in fine working order as they were pulled off my own car only due to upgrading or bought and no longer required.
Im in Brisbane Southside, but will send anywhere at buyers expense.
Email me HERE if any queries, questions, or more pics.
Thanks. :sorcerer:
R32 GTR Gearbox with transfer case- $1000
Traveled aprox 72,000kms, synros are perfect, was only run behind a stock motor.
Gearbox Pic 1
Gearbox Pic 2
Transfer Case Pic
Impul Hi-Power Ecu: $250
- Better air fuel ratios
- Takes out speed cut
- Increases rev limit to 9000rpm
- Tweaked fuel maps so you can run more boost safely
- Plugs straight in, no other modifications required
Impul High Power ECU Unit Pic
R32 GTR brake lines for all four corners-$50
R32 GTR Intercooler piping -$100
R32 GTR Thermo Fan -$100
- Perfectly Working Thermo fan only removed to gain extra space in the front
R32 GTR Fog Lights -$100
- Fine working factory Fog lights!
R32 GTR Springs and Inserts -$300
- Need to pass compliance inspection or clear a defect?
RB26DETT Brand New OEM Nissan Water Pump -$150
- Brand New still in the box!
R33 GTR RB26DETT stock cam gears-$50
- only removed due to upgrading to adjustable.
Edited by CameronBNR32
  • 5 months later...
Still keen to check some close up pics off the rims!
Sorry, have been abit busy. I Took some pics of the rims today..
Click here for GTR Rim close ups
Will take the rims for $500 if you are cool with that?
Got a quote to get them shipped, so can pick up right away!
Just need an adress? Give me a call on 0412913213 or post your
number if you want me to call to arrange payment?
Thanks Joey...
Thanks Joey...
Hey,
$500 is too cheap for me sorry, for the condition they are in I believe $600 is cheap, I've seen sets that are in worse condition go for ~$700
Hey,
No worries mate, shipping to were i am will cost me $150-$180
But...
Whats the approx wieght each? So i can get an exact price on shipping?
Thanks again
Joey.
But...
Thanks again
Joey.
Hey the rims weigh 7.5kg each
thanks
  • 3 weeks later...
  • 3 weeks later...
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
