A few hours to kill?
I agree with Simon, start at Coppins Crossing and go all the way down through the Cotter to Tidbinbilla, then keep on going past Tharwa to Honeysuckle (Canberra's BEST ROAD) and if you still want more you can move onto Ororal Valley.
https://www.sau.com.au/forums/topic/131251-places-to-go/#findComment-2429730
most of the day? bateman's via the clyde, on to bega and across to cooma via brown mountain. smile for the camera before the crest of a hill near bega sorry can't remember how far but it's open country so speed at your own peril.
a few hours? head up the federal to wards sydney and take the moss vale exit, head towards wollongong via kangaroo valley. get to the gong, turn around and do it all again.
https://www.sau.com.au/forums/topic/131251-places-to-go/#findComment-2429764
Open country you say? hmm very intrested think ill hit canberras BEST road and see what shes all about, comming form the gold coast we have some excellent mountain and open roads stacks of fun!
Well cheers for that guys looks like this weekend wont be as boring as the others! :P
https://www.sau.com.au/forums/topic/131251-places-to-go/#findComment-2429825
Hmm.. I occasionally kill some time out on Coppin's Crossing and Uriarra road. Doesn't take that long, but it's fun. Comes to an all-too-abrupt stop though when the road suddenly becomes a dirt track.
I love the twisty stuff towards the end of the run. Out there is where I found the spot I got the photos i'm using as my sig & avatar. On the downside, my front bar always ends up splattered with former insect lifeforms.
Got a couple of days off now... Might have to check out some of these other suggestions :P
https://www.sau.com.au/forums/topic/131251-places-to-go/#findComment-2429913
by Honeysuckle creek, you mean Apollo Rd. and yes, it one of the better roads around. but BE CAREFULL!!! if you dont know the road well, it can catch you out in a bad way and it could all end in tears, or worse... :D
i know the road quite well and i still am carefull when driving along it. its not the smoothest either, and with coilovers (or any stiff suspension setup), one bump can throw you off line and into the wall or off the cliff face!!! also, many bike owners know of it too, and those boys often get up there and have a go...
i have quite a scary tale of a cruise which happened along there a couple of years ago with the R31 club boys. i've told it before (i think...), so if you wanna know how bad and easy it is to loose it up there, ask me the next time you see me....
but i reckon it is Canberra's true touge, and if you make a quick pass along it, your doing bloody well for your self!
https://www.sau.com.au/forums/topic/131251-places-to-go/#findComment-2431494
That was almost a very very memorable day, and not for good reasons. As Luke says, don't take that road lightly.
https://www.sau.com.au/forums/topic/131251-places-to-go/#findComment-2431666
Apollo Rd used to be great before the bushfires. After the fires the edges of the road has curled up and the trucks heading out that way have torn the road up quite a bit compared to what it used to be. Really wish they would fix it up to its former glory.
Still a great drive, just be careful as everyone else said or it will end in disaster (and with no mobile reception its a long way to walk if you prang your car).
https://www.sau.com.au/forums/topic/131251-places-to-go/#findComment-2431907
Honeysuckle is the tracking station at the end of Apollo Road, sorry for the mix up.
Agree with above.....speed at your own risk man....first time I went up there in the FTO I almost got airbourne at one unexpected very sudden dip.
There's also a cattle grate 3/4 of the way up so watch out for that!
Beautiful views too on your way up....would make for an awesome video clip if you did it right.
https://www.sau.com.au/forums/topic/131251-places-to-go/#findComment-2432465
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
