I'm after a windscreen washer reservoir bottle, the mini water pumps (attached to the bottle normally), and all hoses that are required for the windscreen washing system to work (theres also a small one-way valve somewhere in the hoses that i need)
can be from any car - so anyone with a half-cut in brisbane
please let me know and i'll take them off your hands!
cheers,
Warren
https://www.sau.com.au/forums/topic/131494-wtb-washer-bottle-and-hoses/
stephen22 - thanks mate. who is patrick? who does he work for? i'm not after one from a wreckers as they will want an arm and a leg for one and really its nore worth much
nv_n01 - its cool if its from a cefiro as long as it has all that i'm after! send me a PM when you know with a reasonable price...
where is he located?
i'm keen for that price.. but i don't like just ringing a random person unless they are expecting me to call or unless they work for a company..
i've sent you a PM stephen..
sure you didn't see a coolant overflow bottle?
i thought i saw one too, but when i went to look all i could find was a coolant overflow bottle :rolleyes:
if i'm wrong. please tell me as i would be happy to get a supercheap version
Hmm could have been either actually - didn't look that hard but swear i remeber seeing the little plastic pump on the side of the bottle. I can neither conrim or deny then... maybe go in and ask them?
still waiting for people to get back to me with pics and descriptions etc.
am open to other ideas everyone!
realisticalyl no one is goign to buy one so if you have one this might be the only chance to get rid of it!
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
    • Why are you so adamant on going M12? Why not follow Brad (GTSBoy) suggestion. You're talking moving from a 1/8" size, to a 1/2" effectively. 4 times bigger. Why skip the commonly available sizes in between? The bigger you go, the more likely you are to strip the threads out at a later date, as guaranteed, someone will put a huge spanner on the M12 and really tighten it up, and you're only in thin wall, so not a lot of threads to engage!
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
    • Probably gonna remove manifold and turbo. I’m not sure if I can get M12 x 1.5 air tight. Could use high temp Loctite 246 or something similar, but I don’t know. Maybe it’s just best to remove everything again and weld an 1/8NPT on there instead.
    • Yeah, saw the ratios, not impressed. Would like the punch I have in the first gears now. With those ratios it won't be the same.  Also want the h pattern gearing, or at least a quiet gear set that don't need to come apart for service each year. Looks like the only "reasonable" way Is a 8hp70 transmission, but where is the fun in that🤷‍♂️
