taken on da 350z.?
Guest nizmoboi
Hey yall...
Any of yall taken on da new 350z..?
I just wanted to compliment a fellow Nissan product.. I was cruizin on Sat night doing 100km/h, when dis 350z came up to play anywayz i dropped down to fourth then pressed it hard,,, my eyes dropped when i saw the 350z pulling from me... Anwayz i decided to slow down and drop down to 3rd and try and beat him in the R33's , midrange,, anywayz i pressed it again and sure enough dis thang PULLED ... i hate to think if they had of come out twin turboed like the Z32's...Damn i was beaten but happy cuz it was a fellow nissan and not a bombadore.... The guy was smiling and cool about it too which made it fun... Yeah by da way i had 3 people in my car, dont know if this made much difference.
https://www.sau.com.au/forums/topic/13162-taken-on-da-350z/
  • 4 weeks later...
Guest INASNT
Originally posted by dAVE
stock vs stock, they have more power than a gtst by about 25kw. Both around 1400 kg too. So I would assume the 350z would work. Also, with our skylines, i think they are way more tempremental, so u would find with even a few mods a 350 might hand your ass to you on a plate.
only mod i would put on a 350z is a twin turbo veilside kit! :D
https://www.sau.com.au/forums/topic/13162-taken-on-da-350z/#findComment-298473
  • 1 year later...
Well i have to say i love the Z, I have a black/orange Track and all you guys in your modified skylines blowing away stock Z's isn't much to brag about, i know cause i also have a 235kw r33 and if i spent the equivelent dollars on my Z then i think you would all be in trouble....GO the Z...and the Liners of course! Cheers to all, Jason. :rofl:
https://www.sau.com.au/forums/topic/13162-taken-on-da-350z/#findComment-1268407
    • Hopefully it ends up being something manageable, like a hone, rather than a full bore—it would be a huge relief if it’s not as bad as it looks. Hang in there; these setbacks are annoying, but it sounds like you’re handling it as smartly as possible.
    • At the end of the day, it’s all about understanding the odds and being comfortable with the potential cost, whether it’s horsepower on a build or chips on a roulette table. And I have to say, the Laine example made me laugh—some people really do embrace that carefree, “roll and see” attitude!
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
    • https://yariksteel.ru/manual/R33/Skyline_R33_elektroprovodka.pdf   Page 18 should be what you want for the Dash Cluster wiring. Though, you don't need the dash plugged in to get the motor running. What you want is power as how GTSBoy said. You need to power the ECU. Find in the above link the ECU pin outs (Verify them before just connecting them up from things written on the internet). Find anything needing power, give it power, find anything needing ground, give it ground. Then give the starter motor power through a big cable, and bridge the solenoid on the starter straight to power too.  ECU will be on, and when you give the starter power, it'll spin the starter motor, and it should start. I also hope you have a proper stand, and not just the engine sitting on some wood. You will want it bolted down properly.
