hi all.
i bought these a while ago with the intention of putting them in my mistress but have decided to sell and wait till i can afford a full adj' coilover setup!
i bought them off ebay a few months ago for just over 270.
i feel that $200 is a fair price. 200 INCLUDING shipping that is. pick up in the mornington peninsula area would be alright too (say $180 for pick up).
PRICE DROP!!!- NOW ASKING $170 INCLUDING POSTAGE
according to the ebayer i bought them off they lower the car 30-35mm.
dont know for sure but ive been told from a reasonable source that they are much stiffer than the stock springs too (but dont hold me to that!)
to contact me you can do the obvious: pm or reply in this post. or call/ sms my mobile on 0423 043 495. james is my name.
not particularly negotiable on price- unless you can show me a genuine place that sells the same item new for much cheaper.
cheers. james.
sub wooofers go bump bump bump bump.
just like me in this reply.
bump
EDIT: if there is anything in the list in my signature that you are trying to sell that you are willing to swap for, we can make some sort of arrangement. cheers!
alrighty then.
i called up king springs and they themselves had said that the rear ones are good for a both the GTS-T and GTS-4 (they said "its suitable for both the rear wheel dirve and the 4WD" so i assume that its ok for the GTR) HOWEVER the FRONT springs are only good for the gts/ gts-t.
PATTO: steven from king springs said that it lowers it 25- 30 mm. which isnt much but ive driven a 32 with these springs on them and it look good, and is easy to drive aswell.
cheers. james.
If you want to ask any more questions please call them on (07) 5539 6700 and quote the part numbers KDRL 102 (the rear ones) and KDFL 101 (fronts)
this was the effect of King Spring Sport lows after only a day or so, still got a bit of dropping to do:
http://www.nissansilvia.com/forums/index.p...t&p=2333355
fair bit lower, but most importantly alot better handling.
Edited by nisskid
bump!
desperate to get rid of them, not desperate to lower the price though.
hurry up and buy these someone!
cheers. james.
please read above.
lowers the car 25-30mm.
take a ruler to your car and find out what the height is take off 25-30mm.
BAM! thats how low it sits.
cheers.
im located in VIC so if anyone want to pic up from here...
however a mate is selling these in sydney.
heres the link.
http://www.skylinesaustralia.com/forums/in...howtopic=134177
cheers. james.
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
    • Yeah that looks like great caster, but I'd suggest trying less front camber some time and seeing if it helps with braking without reducing mid corner speed too much
    • I ended up setting the rear 5mm higher than normal to give some clearance.  My plan is to run the least camber I can in the rear which I think with the extra width is going to need to be -1.75 to -2.00° just to get clearance.  Guards have been rolled and pulled as much as they can/I would be wanting to.  front has the Acostal knuckle with the KPI change and the drop etc. So should be okay with the existing settings I have run with AR1s etc Front: Toe total -2mm(1mm out each side) Caster +7.5° Camber -3.8° Ackerman +15°
