Ive got 10 sets of clear front indicators coming in.
These are to suit the Stagea WNC34 (S1) only.
These are very hard to find and they normally retail from $100-$130.
Special Price - $70 delivered.
Finish date - 14/09/06
Payment due - 18/09/06
Buyers:
1/ Talej - paid - sent.
2/ Ska- paid - sent.
3/ wagonwheels - paid - sent.
4/ Burns - paid - sent.
5/ FLYSLY - paid - sent.
6/ StageaGirl - paid - sent.
7/ wagon - paid - sent.
8/ RSFour - paid - sent.
9/ private buyer - paid - sent.
10/ humble
11/ CruiseLiner
12/ STAGE-A
13/ qikstagea
14/ jake32
15/
16/
17/
18/
19/
20/
I'd love to, but just dont have $70 spare..... had to push it to get the clear sides, which were $50! :P But still, brand new from nissan these are worth $120 EACH!!! Not a pair of them!! This is a BARGAIN!
Got my package today... thanks! Slight problem that I'm not quite sure what I should do though... my car has square plugs and the clear indicators have round holes????? :(
Are the plugs on my car not standard for some reason? Where can I get some round ones from?
Talej - You should be able to swap the plug, wiring and light bulb socket from your standard ones to the clear ones.
FLYSLY - thanks :woot:
yep - I managed to get it all sorted out. swapped the plugs and bulbs and I had to do a little bit of filing on the clips because they were too wide for some reason. All in and looking great now.
Thanks :D
Thanks :D
Excellent :woot:
Dude you are a dead set LEGEND!
Got mine today, had to cut a tiny bit out of my front bar as the two prongs didnt quite fit, the top one on the standard part is only half as wide, a two second tiny cut with a stanley knife and BAM, swapped the plugs and bulbs and put in.
Done, THANK YOU!!
Done, THANK YOU!!
Excellent :(
