Hi...just wondering if anyone else has had this happen. It has only done it three or four times over six months. When I turn off the ignition, I hear this loud moan/groan type sound coming from the rear of the car..I am thinking its the fuel pump in the tank (I guess theres one there)..anyone had the same thing happen or have any ideas??
Scott.
I beleive that some of the ECCS systems run the pump for a few seconds after shut down to build up fuel pressure. They do this to minimise the chances of heat soak boiling the fuel and causing vapour lock in the fuel lines. They also have a electronic solenoid on the vacumm line to the regulator to give the rail full pressure. So it could well be your pump building up full pressure.
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
    • Sounds like a misfire. Check fuel pressure and don't even think about going into boost while it's like this unless you enjoy engine rebuilds.
    • Just. Gasping. Here. Just. Gasping.
