Space Goat Posted August 28, 2006 Share Posted August 28, 2006 hi... im in the middle of wiring up my car and i screwed up... its a rb25det neo... i went to start the car... fuel pump charged up, starter motor cranked... and cranking and cranking... but no start... ive checked my spark and my injector wiring and its all correct... i then went to the computer and it smelt like the smell you dont like to smell near electrics... i opened it up and i found a diode or resistor to be had it... ive got another computer on the way but i want to know what caused it to let go... the number of the diode/resistor on the computer chip is D620... could anybody tell me what that diode is... or where can i get an electric diagram of the actual computer... if i worked out what pin fed this diode i could work out where i went wrong by using the ecu pinout... i cannot follow it back on the card because the card is multi layered or something like that.... thanks for your help Link to comment https://www.sau.com.au/forums/topic/131995-my-computer-shat-itself/ Share on other sites More sharing options...
Wheezy Posted August 28, 2006 Share Posted August 28, 2006 dude, you didnt end up use a relay for the fuel pump did you? BOOOM HEADSHOT.......too much current going to the ECU because of that relay not there..... Link to comment https://www.sau.com.au/forums/topic/131995-my-computer-shat-itself/#findComment-2444211 Share on other sites More sharing options...
mad082 Posted August 28, 2006 Share Posted August 28, 2006 did you change coilpacks from standard to an external pack? if you did then that could be the problem. my mate did it with his. put some MSD coils in and got the wrong ones and fried his ECU. Link to comment https://www.sau.com.au/forums/topic/131995-my-computer-shat-itself/#findComment-2444398 Share on other sites More sharing options...
Bl4cK32 Posted August 28, 2006 Share Posted August 28, 2006 cubes had his power fc fixed by force electronics for around $150. Link to comment https://www.sau.com.au/forums/topic/131995-my-computer-shat-itself/#findComment-2444403 Share on other sites More sharing options...
Space Goat Posted August 28, 2006 Author Share Posted August 28, 2006 yeh wheezy i didnt *gets in line for somebody to shoot me in the head* oh well ive found another computer... ill make sure that i put a relay through for sure now... what size relay do i ask for when i get it??? 10 amp??? Link to comment https://www.sau.com.au/forums/topic/131995-my-computer-shat-itself/#findComment-2444538 Share on other sites More sharing options...
James_03 Posted August 28, 2006 Share Posted August 28, 2006 (edited) Providing your loom came with the eccs and ign relays which is should have, then you should have a spare green relay left over near the kick panel. Use that, if its still there. Otherwise go the wreckers and grab another one off a r31. Edited August 28, 2006 by James_03 Link to comment https://www.sau.com.au/forums/topic/131995-my-computer-shat-itself/#findComment-2445219 Share on other sites More sharing options...
Space Goat Posted August 28, 2006 Author Share Posted August 28, 2006 Providing your loom came with the eccs and ign relays which is should have, then you should have a spare green relay left over near the kick panel.Use that, if its still there. Otherwise go the wreckers and grab another one off a r31. thanks for that ill do that... does anyone know where i could find a electrical diagram for the actual computer or tell me what the diode # D620 connects directly to Link to comment https://www.sau.com.au/forums/topic/131995-my-computer-shat-itself/#findComment-2445628 Share on other sites More sharing options...
