my 180SX stolen today mon 28 aug at 3.30pm from paralowie. if you see it call the police and/or me on 0402 903 865 (24/7). i suspect it might still be around the salisbury area.
looks like this:
he rang me (private number) to have a look at the car (advertised in the trader). he came, test drove, and when we got back to my house he turned the car off. i got out (big mistake) he played around with the gear stick to look like he was checking something, started it up and drove out my driveway and off he went.
male, age 25, 5'9", name 'Daniel', short light brown hair part in the middle, short gotee beard, wore glasses, cock eyed MOFO, black jacket, appearance a bit scruffy/untidy. looks like a nerd, acted like a nerd or somewhat religious doorknocker.
he walked to my house (strange), says he came by bus from north east rd to the woolworths shops in paralowie (no bus does that route, let alone in half an hour), carried a latex glove with him (dirty hands he said), didnt carry a street directory ???. probably used pay phone at the woolworths shops at the corner of whites and kings rds. must have had an accomplice waiting there at the shops.
just didnt click. i was hoping for a sale.
if this guy tries it again to inspect a car thats for sale, play along and pin the MOFO down.
thanks
Edited by TRUST_180SX
Up on valhalla and rexnet too.
http://www.valhalla.net.au/forum/viewtopic.php?p=19326#19326
http://www.rexnet.com.au/forum/index.php?showtopic=56344
Soon half of Adelaide's car clubs will be looking for this crim.
Edited by Howie
Bad luck mate, i see your car on a regular basis, if i see it i will definitly get in contact with you and try to reap some revenge!
Good Luck. ITs sad that you cant even sell your car these days without having to worry...
diff dude. 2nd person in it now.
if i can sell the 34 now for $33k registered thatll be a great help. otherwise ill be losing too much in too short a time.
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
