Pro Tuner or Power Writer?
This is the info I have
The HKS Rotrex unit comes with the HKS F-Con SZ engine management system. This is an advanced piggyback style EMU designed with a conservative tune in mind. It is a direct plug and play unit that comes with an external harness terminated with OEM style connectors. This unit may only be tuned by a certified HKS Pro dealer
https://www.sau.com.au/forums/topic/132349-hks-pro-tuner/#findComment-2452368
I think BD4s over east are your only option in Australia. (http://www.bd4s.com.au)
Pity - would loveto see a local fittment of the kit!
https://www.sau.com.au/forums/topic/132349-hks-pro-tuner/#findComment-2453418
Unfortunately yes BD4s are the only authorized HKS Power Writers in Australia :P Means you either come here or they fly to you...
There are rumors of other places being able to tune them too; but none have really become reality.
https://www.sau.com.au/forums/topic/132349-hks-pro-tuner/#findComment-2454158
Sorry for Off topic Chris
But is your V35 the one parked in West Perth with the misses in it at about 3.45pm weekdays? Has private plates?
Dan
Yes Dan that's mine.
I work in the old Fluor building 600 Murray st.
You work around there?
https://www.sau.com.au/forums/topic/132349-hks-pro-tuner/#findComment-2456340
Looks like I'll need an Emanage then
Apparently they come pre tuned and the previous owner has had 20,000kms trouble free running with it.
I think first off may run it up on the dyno to make sure if it's running safely and if not decide on a plan of action then
https://www.sau.com.au/forums/topic/132349-hks-pro-tuner/#findComment-2456347
Chris , check with XSpeed. There was talk a while ago about Hanson getting the FCon tuning package as he brings a lot of HKS gear in.
They say the package is excellent if you can read japanese... :):P
Cheers
Ken
https://www.sau.com.au/forums/topic/132349-hks-pro-tuner/#findComment-2457083
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
