Hey all
just letting you know before someone gets on here and starts to bag the absolute shit outta me. As you may know a few of us went on a cruise last night, to the Box Hill Bowling centre. We played a couple of games and in the first one i came 2nd with Amber following up last, failing to reach the score of 100 (84 or something like that), but in the second game she took over. I dont really know how cause she looked quite retarded when bowling:D j/k. She beat me fair and square, but one day i will have my revenge. :D Anyways, good night had by all and Chop, nice effort with the wiper blades.
Dave
P.S: By the way, if you can get the footage of Horus bowling, GET IT. Absolute pissa hahahahahahahaha. Now that is a troubled man. j/k:uh-huh:
https://www.sau.com.au/forums/topic/13252-ambz-we-will-meet-again/
HAAHAHAHAHA
OMG!!! LLOLL HOWW FUNNYY
COVERING UR ASSS DAVE
HEHEH
last night was fantastic
havent laughed like that in ages!!!
dave ur still crap!!!
beaten by a girlllllllllllllllllllllll half the size of u!!
haah the pink bowling balls rocks!!
steve is teh SAU bowling champ such style such skillss too bad its not enough to keep him from nearly falling flat on his face in the car park
lolll
ANDREW UR CRAP! hehehehe
and sameer... oh poor sameerrr ur teh highlight of the bowling night
lolllss how much we laughed at the way u bowl
lollll
great night guys and girls
gotta do it again sometime soon!!
:bahaha: beaten by a girl :Owned:
horus bowling: gold man, gold!
I'd also like to pay my warm regards to Ash and Andrew and their lack of bowling skills against my own .. usually I come behind of all my friends, but now i feel so much better! betta luck next time fellas! :D
...we kinda went separate ways after that, 'cause lotta people had to get up early for work and all.
inark and funkymonkey *finally* turned up at about 12:30 after getting "lost" (there's a big RED sign you can see for 20km around.. you goons), we went for a short squirt to deakin, i cracked an already cracked bumper (the speed bump jumped out at me i swear). A few of the guys went out for some food, but I called it a night as it was about 1:30am or so
you get home b4 it started raining? have to get the umbrella out over that passenger window? :D
i was behind him...
in bowling that is :D:D:D
We got rain all the way back to tulla... and this SS that wanted to go ME ... hehehe. i scared him.
I love the bowling. That was a great idea... im no longer a ten pin virgin.
finally me a few other faces, i'm liking this
Hey guys,
last nite was cool, i had a great time. I hope it was the same for everybody else too.
Ambzz it was my pleasure you don't have to thank me for nuttin!
:uh-huh:
Hey Ambz im sorry bout the shit as well wit "SAD" since I have put him in his place and he's sorry too. His problem at this point in time doesn't seen serious.
I tink I should tank u for talkin to me it made the world of difference.
Ne ways guys take it easy
Seya
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
