That looks hot, Burns. The P1's set it off nicely.
Is your FMIC a cross-flow design one, where the return pipe goes back towards the passenger side to use the standard holes under where the air-box would be? If so, is the return pipe behind or under the core (can't really tell in the photos)? Where did you get the cooler from and roughly how much was it?
Nick
https://www.sau.com.au/forums/topic/132697-happy-stag/#findComment-2458763
Yep it's a Dayz with a bit cut out for the intercooler.
It's just a R33 brake cylinder stopper.
The return pipe is behind the core and it uses the stock holes but they have been enlarged for the bigger pipes.
It came with the car so I don't know what cost is. It's a Blitz kit.
It took 4 months to get the parts and another month at the panel beaters but the outcome is fantastic.
Being backed into by a Prado wasn’t that bad a thing after all.
https://www.sau.com.au/forums/topic/132697-happy-stag/#findComment-2458773
Damn your car is nice, is that a dayz kit? And the P1`s look rediculous
Is that a brake cylinder stopper i see? If so from what car was it meant for?
Excuse my ignorance but wtf is a brake cylinder stopper? :rant::woot:
:D
https://www.sau.com.au/forums/topic/132697-happy-stag/#findComment-2484841
Excuse my ignorance but wtf is a brake cylinder stopper? :P:D
:ermm:
This (the blue thing I outlined in the photo) is the brake cylinder stopper - it attaches at one end to your strut tower, and on the other side to the end of your brake master cylinder to stop/reduce firewall flexing when you're hard on the brakes.
Less flex in the firewall means better and more consistent braking, and a more consistent pedal feel.
https://www.sau.com.au/forums/topic/132697-happy-stag/#findComment-2486088
And excuse my ignorance but what is P1's?
And why is it ridiculous?
Looks nice Burns..My brother wants me to get a FMIC... how much difference does it do to performance?
HAHA thats so cute!!! "what is P1's?"
Thats like asking where babys come from or something lol
gotta start somewhere...
https://www.sau.com.au/forums/topic/132697-happy-stag/#findComment-2487145
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
