Ok, to work in conjunction with an aftermarket ems when upgrading injectors, is it better to run high, or low impedance injectors?
That is, either stick with the high impedence injectors on my sr20det and get larger ones from an s15 (relate to r33 injector setup), or should I get a fuel rail made up and run some low impedance injectors?
The reason I ask is because, if it's a lower impedance, then less resistance and therefore obviously higher current - therefore is it safe to assume that the injectors would operate a lot faster?
Or is this only the case in BIG horsepower engines, and not something I should worry about?
Cheers
https://www.sau.com.au/forums/topic/13284-high-or-low-impedance-injectors/
Hi PSIKO, never seen any evidence of hi or low impedance injectors being better or faster. It is the fuel feed system that matters, side feed injectors are way more expensive to buy, so we like to change to top feed.
Hope that helps.
well apparently this is so, but when you don't run any form of aftermarket management that can determine it, they all run under the same resistance and therefore same properties
later on you can set it so that the injectors open faster (more current, lower resistance) and upgrade the springs so that the injectors close quicker (needed with higher hp and rev's bla bla)
but basically for my needs, its irrelevant which I go for, only depends on how much I want to pay, and whether I intend to upgrade later (back-fed better for this)
therefore back-fed (top-feed) is what I'm going for :P
Would like to know how this works. My (limited) understanding is that electricity travels at the speed of light, and if you up the current to a circuit designed to operate at a specific amperage, all you do is risk doing damage.?????
anyone thow some light on this for me?
Cheers
Steve
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
