1993 R32 GTS4 Skyline with;
18 inch rims (2 X undamaged with %90 tread, Nankang rubber)
cat back exhaust system,
dual stage turbosmart controller with switch,
apexi air intake,
k-sport coil overs /adjustable <less than 5000k>
Tomei short shifter
95% interior in good condition, no damage in engine bay, Gearbox is good, rear light assembly still good, drivers door good, bonnet has minor dent and front bar is cracked.
Recently had major service with motul throught the car and platnium plugs
Will consider front cut offer <minus suspension>
Currently car is being sold as one piece for $3500 <minus suspension> or highest offer.
Rear quarter panels have suspected chassis damage.
Car located in Ryde NSW. <pics soon>
Edited by cyphr
https://www.sau.com.au/forums/topic/133030-white-r32-gts4-rb20det-wreck/
  • 3 months later...
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
