hey all
i think we should make a meet of it, hands up whos comin
so far i think pred666 is contemplating runnin, il b goin, 32 envy, and cant remeber who else
cost is $55 for unlimted runs
doors open at 5 with racing startin at 6
best to get there early.
i suggest meet at 5:30 at calder, in the scruitineering (spelling) section if you are running or just cruise on in if your spectating and meet up in there...
lets gets some good numbers goin and make a little meet out of it, be more fun with more sau guys...and any newbies feel free to come down and join us, meet the crew etc
https://www.sau.com.au/forums/topic/13304-calder-4303-hands-up/
well guys i have jsut spoken to DZNUTZ on the phone(yes the ba**ard called me at like 2 am lol
we have decided we will attend, and he will be running his car to see what it can do :( (i am all excited now hehe)
jet concidering you know the guys at calder or something, do you think it would be poss for us to park inside or something, instead of in the gravel pit outside they call a car park??
if u know em why arent u organising cheap rates?
thats one thing i miss about NZ... drags are cheap... like $15 mind u so are skylines... damn.
(but i was too young to appreciate it as i didnt have a car then...)
My car has been retuned, running 13boost, and running hard so be scared. Picked up a helmet ready tonight so i wanna go..
Me gonna kick ya butts ... just hyping up the competition spirit here! :D
My only slight prob could be getting out of work early.. i'm crossing my fingers, should be ok, but i am meant to finish at 5:30pm.
Rain wise: I believe if its called off - you can get free entry back to the next event.. Don't think that will happen though. Forecast for tomorra is :
Fine apart from an early morning shower or two. Afternoon sunny periods.
Moderate southeast winds.
Min 10 Max 21
Perfect turbo weather!
Spectator is $17 .... better value to run if u ask me :D
ok..well put ya name down in here if you're still up for it.
I don't wanna go run by myself and won't bother otherwise :D so get to it..
Tomorrow (Friday) I reckon we throw the thread out in general VIC area for spectators and some cheer support.
17 to spectate, so pay 55 and just run dj, u gotta start somewhere, no 1 is gonna give ya shite or anythin like that
i know 1 guy who works there...hes just a commoner, hehe
and last time i was gonan have to pay aswell cos apprenlty the boss is gettin real tight..but i was runnin so had to pay the 55 anyway
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
