Hey guys. When I purchased my GTR33 it came with a Kakimoto 3" Cat back exhaust. I am shooting for about 700-750WHP when I am done with my R33. Now I of course realize that I also now need to upgrade my downpipe which appears to be stock size or very close to it. However my real question it this.
I have been told that Kakimoto makes 2 different kinds of 3" exhaust, a racing one and an every day one. I am told I have the every day one. Is this true? Are there 2 different types? My exhuast appears to be 3 inches from the cat back, has manderal bends, a resonator, cat and muffler. Now I am used to running straight 3" pipe with only a muffler so I would of course remove the cat, but I was unsure about the other stuff. Is mine a decent 3" or would a different 3" be necessary?
I have also heard that a 3.5in exhaust is ideal for a GTR33 especially with my power goals, so would a 3.5in make a signifigant difference?
I guess I am just trying to find out if my 3in Kakimoto catback exhaust (as I said I would also upgrade Down Pipe) is sufficent for my 700-750WHP street car, or If I need to upgrade to a different 3" exhaust or even a 3.5". Thanks guys.
-Sayajin
  • 1 month later...
if it has a cat, ressy and a muffler then i wouldn't think it be a racing exhaust.
700awhp is a big figure.... i would have though 4" straight through would be more what you needed.
remember: (theoretically) turbocharged cars shouldn't run exhaust because turbos hate back pressure. whereas atmo engine need some back pressure to make low/mid range torque.
if i was aiming for 700hp at all wheels (which is about 525kW) then i would rather a bigger than neccesary exhaust than having the engine choking because it cant get rid of its exhaust gasses quick enough.
is the car going to be driven (or attempted to be driven) on the road? if so then you will be restricted as to how open you can have your exhaust. if its gonna be a track car then just go big! you dont need to worry about mufflers for the track.
so in conclusion, i would upgrade your exhaust.
if its going to be a track car then get 4" or close to pipe with no muffler or maybe just a ressy.
but if its going to stay on the road then keep the 3" and just get rid of the ressy and cat (but you run the risk of gettin a little yellow sticker if you do that)
hope this helps
I have a kakimoto and theyre just excellent wouldnt know why youd wanna get rid of it....and thats a large figure to be chasing! my advice would be keep it for now and see how you go if you need to upgrade well then do so but up until then id keep it theyre a rare thing over here
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
