Gb: R32, R33, R34 Skyline Carbon Fibre And Fibreglass Bits
  • Replies 272
Rflirty4 added to the list... just awaiting confirmation of stock first.
All the others in Order #2; your stuff is en-route now, sorry for the delay.
Well he said he's just waiting for a moment to get to the post office over there - it only takes a few days after that and I'll be sending everyone's stuff express once it's here!
OK I got an answer for the CF boot lid... you can get these in the following "colours":
Black CF (what we usually see in AUS)
Silver CF
Blue CF
Price I've been told is approximately $1k + freight... they are as per the photos posted on page 1. Obviously a few things will need to be transferred over (stop light, locks, latches etc)
Personally, I wouldn't bother unless you're made of gold.
Silver CF
Blue CF
any idea on freight cost?????? cause i really dont mind paying $1000 for the boot lid itself (as there is only one guy in australia that i have had an answer back on and said he can do it but he wants up front payment before making it and sound a bit dodgy eg. no pick up and bank deposit only even though he is in sydney and close to me!!!!)
maybe if more ppl want them we can split the freight costs?
and by the way im after black cf
thanks
Justin
Cost of freight will depend on the way we send it... obviously it will need to be packed very well; insured and tracked - these three items don't come cheap; add on more if you want it in a hurry too.
I will dummy up some numbers :P
thanks
i would appreciate that heaps, if other ppl are interested in these boot lids for r34 please voice your interests now and we maybe able to save on the shipping cost...
by the way im not in a huge rush so if i can save on the cost of freight by sending it economy, by boat i dont mind
I'd estimate that by sea; you'd be looking at an extra $100-$150 in freight... those in Sydney can then make the effort to come collect it from me as I really cannot be bothered to lug around a boot lid :) (I'm small, so lay off)
I'd estimate that by sea; you'd be looking at an extra $100-$150 in freight... those in Sydney can then make the effort to come collect it from me as I really cannot be bothered to lug around a boot lid :dry: (I'm small, so lay off)
mate that price of $1000+$100-$150 freight is fine. can you go ahead and order a black cf one for me please. just let me know when you need payment we can meet up and i can pay you in person. and pick up is not a problem.
also is there any chance of getting the boot lid made without the key barrell hole and the middle brake light hole? if so i would appreciate that but if not it doesnt really worry me.
thanks
Justin
0425291404
Justin; I'm not going to promise you anything yet - I will have to get in contact with this guy and ask for confirmation. I don't want to promise something I can't deliver that's all.
If he's all good with it then yeah, we'll go ahead with it ;)
If he's all good with it then yeah, we'll go ahead with it :laugh:
satanic
no problem mate just let me know when confirm. i appreciate your help.
thanks
Justin
    • You won't need to do that if your happy to learn to tune it yourself. You 100% do not need to do that. It is not part of the learning process. It's not like driving on track and 'finding the limit by stepping over the limit'. You should not ever accidently blow up an engine and you should have setup the ECU's engine protection to save you from yourself while you are learning anyway. Plenty of us have tuned their own cars, myself included. We still come here for advice/guidance/new ideas etc.  What have you been doing so far to learn how to tune?
    • Put the ECU's MAP line in your mouth. Blow as hard as you can. You should be able to see about 10 kPa, maybe 15 kPa positive pressure. Suck on it. You should be able to generate a decent vacuum to about the same level also. Note that this is only ~2 psi either way. If the MAP is reading -5 psi all the time, ignition on, engine running or not, driving around or not, then it is severely f**ked. Also, you SHOULD NOT BE DRIVING IT WITHOUT A LOAD REFERENCE. You will break the engine. Badly.
    • Could be correct. Meter might be that far out. Compare against a known 5 ohm 1% resistor.
    • @Murray_Calavera  If I were an expert I wouldn't be in here looking for assistance.  I am extremely computer literate, have above average understanding on how things should be working and how they should tie together.  If I need to go to a professional tuner so be it, but I'd much rather learn and do things myself even if it means looking for some guidance along the way and blowing up a few engines. @GTSBoy  I was hoping it would be as simple as a large vacuum leak somewhere but I'm unable to find anything, all lines seem to be well capped or going where they need to be, and when removed there is vacuum felt on the tube.  It would be odd for the Haltech built in MAP to be faulty, the GTT tune I imported had it enabled from the start, I incorrectly assumed it was reading a signal from the stock MAP, but that doesn't exist.  After running a vacuum hose to the ECU the signal doesn't change more than 0.2 in either direction.   I'll probably upload a video of my settings tomorrow, as it stands I'm able to daily drive, but getting stuttering when giving it gas from idle, so pulling away from lights is a slow process of revving it up and feathering the clutch until its moving, then it will accelerate fine.  It sounds like I need to get to the bottom of the manifold pressure issue, but the ignition timing section is most intimidating to me and will probably let a pro do that part.  Tomorrow I'll try a different vacuum line to T off of, with any luck I selected one that was already bypassed during the DBW swap.  (edit: I went out and did it right now, the line I had chosen did appear to have no vacuum on it, it used to go to the front of the intake, I've now completely blocked that one off at the bracket that holds several vacuum lines by the firewall.  I T'd into the vacuum line that goes from that bracket to the vacuum pump at the front of the car, but no change in the MAP readings).  Using the new vacuum line that has obvious vacuum on the hose, im still only getting readings between -6.0 and -5.2.  I'm wondering why the ECU was detecting -5.3 when nothing was connected to the MAP nipple and ECU MAP selected as the source. @feartherb26  I do have +T in the works but wanted to wait until Spring to start with that swap since this is my good winter AWD vehicle.  When removing the butterfly, did it leave a bunch of holes in the manifold that you needed to plug?  I thought about removing it but assumed it would be a mess.   I notice no difference when capping the vacuum line to it or letting it do its thing.  This whole thing has convinced me to just get a forward facing manifold when the time comes though.
    • Update: tested my spark plugs that are supposed to be 5ohms with a 10% deviation and one gave me a 0 ohms reading and the rest were 3.9ohm<, so one bad and the others on their way out.
