Bleach1,
Yes AVS wheels are definately worth something. What model do you have on your car? Have any piccies?
They have AVS model 5, 6 and 7. They also have a older model called VS-5 or something like that.
I have 18" AVS Model 5 on my new R33...they are my favourite wheel of all time so far. Pretty expensive if you want to get a set here I think. AVS are made by yokohama or one of the major jap tyre companies I think.
Hope this helps.
https://www.sau.com.au/forums/topic/13355-avs-wheels/#findComment-257922
Yeah, they are the older AVS model.
My brother has them in 17" on his GTR. Have to say that they are quite common on white R32's. About 99% of all the wheels i have seen in this style are white.
I think I have seen a set come up for sale here before, so if you want to checkout what they are worth, do a search on AVS wheels.
https://www.sau.com.au/forums/topic/13355-avs-wheels/#findComment-258774
well i only have 2 on my car now. I busted 2 guys stealing my wheels and they got away with 2 of them. Luckily a friend of mine had 2 wheels that looked similar as well so i put them on the front, except they are 17's so it looks a bit odd. Need to get a new set of wheels. Damn thieves.
https://www.sau.com.au/forums/topic/13355-avs-wheels/#findComment-259306
  • 3 months later...
  • 5 years later...
The Advan AVS wheels are actually worth something, since they're made by a reputable manufacturer.
However, there are some knock-offs using the AVS moniker for their shit wheels.
Post pics of yours, if you want a more accurate response.
https://www.sau.com.au/forums/topic/13355-avs-wheels/#findComment-4666990
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
