I was thinking about posting the exact same question.
My fuel economy is up shit creek. I'm getting 15L/100 OFF BOOST and then 20+L/100 when giving it a bit of stick.
I've recently had a new fuel pump and new timing belt.
What stuff should I check?
Whats there to check with the 02 Sensor?
https://www.sau.com.au/forums/topic/13399-fuel-economy/#findComment-259054
I was getting really bad Fuel Economy a few months ago (lucky to get 200k to a tank) I replaced my o2 sensor 4 a ford unit all is now good.
Long steady drives i get over 500 k to a tank, arround town strapping it i get at worst 400k's.
I would get you O2 sensor replaced.
The ford unit is the same as the nissan one only cheaper and you need to change the plug to the nissan one 4 it to fit. For under $90 well worth it.
Regards
Damqik
https://www.sau.com.au/forums/topic/13399-fuel-economy/#findComment-259291
The o2 sensor is located on the back of the turbo & has 3 wires going to it. I got my replacement one from Barnes high performance Nambor (he can fit 4 u tho I did mine myself)
The Afm is mounted on the back of the air box has about 5 wires going to it, give it a spray with Co Contact cleaner made by CRC
try the following link for more info
http://www.wave.co.nz/~hksnz/techfiles/oxy...orlifespan.html
https://www.sau.com.au/forums/topic/13399-fuel-economy/#findComment-259294
The O2 sensor is only used by the ECU during closed loop operation. Even with a faulty O2 sensor your fuel economy should only drop a bit.
300km to a tank is a significant drop. I doubt it'll be your O2 sensor. Could be a bad tune, fault spark plugs, a blocked/damaged cat.
https://www.sau.com.au/forums/topic/13399-fuel-economy/#findComment-259302
Yeah, I'm talking 300km at BEST.
If I give it a bit I'm lucky to get 250.
I spoke to a mechanic about it today.
He's gonna replace it for me under the warranty I got with my car.
Who says those warranties aren't worth shit hey?
We'll see how it goes hey?
https://www.sau.com.au/forums/topic/13399-fuel-economy/#findComment-259877
  • 3 weeks later...
I disagree. I changed my O2 sensor, and that has made all the difference. I'm getting waaaaaaay better economy then what i did before.
https://www.sau.com.au/forums/topic/13399-fuel-economy/#findComment-292896
Actually skylines spend most of their time in closed loop the only time there not is @ full throttle or accelerating off.
If the O2 sensor is stuffed the ecu gos into the safe (Rich) limp home mode.
Therefore as many people have said replacing the O2 sensor has given them much better fuel economy if you have a stock or near stock car and get shit economy I'd recommend replacing it.
https://www.sau.com.au/forums/topic/13399-fuel-economy/#findComment-293313
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
