  • Replies 41
Blitz Bov.... Tried for three months to get an adaptor plate to fit where the stock one was.... NO GOOD. No one had or could get one. So i had to get my mechanic to Fabricate it on to the pipe leading to the Throttle body. (under the pod). It cost a bit to do it, but it sound's great and looks nice.
I'd show a photo, but i dont have a digital camera.
Cheers
Loz
https://www.sau.com.au/forums/topic/13401-blow-off-valves/#findComment-261222
Well, thought i might of had some boost loss (i got worried when people spoke of "boost leak") But after some under bonnet testing (rev hard and watch valve) i noticed the "button" (copper release thingy) moved down furhter on rev..to seal the BOV . So i took it out for a hammer (foot to the floor) and it all seems fine.!!
Next is the Boost Guage.
and maybe the "Skyline" logo lit up in Blue....
Loz
https://www.sau.com.au/forums/topic/13401-blow-off-valves/#findComment-261291
Cheers
Loz
I haven’t been able to find a adaptor for the Blitz my self do they actually make them?
I think I'll go for a GFB or Turbosmart pop off valve:)
https://www.sau.com.au/forums/topic/13401-blow-off-valves/#findComment-261367
I used a Trust Type R BOV on my GTST. The BOV kit itself doesnt inlcude the adapter however Advan at Silverwater sell the adpater plates for GTS-T so they bolt straight on.
After using a Turbosmart and an HKS SSQV BOV I found the Trust to be a better unit and experienced less idle/stall problems.
https://www.sau.com.au/forums/topic/13401-blow-off-valves/#findComment-262699
holy cow lozza...im not sure if all those series of blitz bovs are the same or not...i've got the same one..and from the look of ur pic..ur one is really really loose...are you sure its not leaking at idle?
unless ur screw has been changed....cause my one you can see about 3 threads after the nut which is about just right...
do u have probs with rev's when coming to a stop after hard run?
https://www.sau.com.au/forums/topic/13401-blow-off-valves/#findComment-263342
The Mechanic's adjusted it to suit with the standard BOV unit connected as well. After disconnected the stock one and now just running the Blitz one... It's a lot louder.... but "seems" ok. After a good run, it does drop the rev's very low...for a split second, then it must seal and all is ok. It's hard to tell if the unit is not leaking... Logic tells me if it was leaking, I'd lose boost pressure on the guage... but it still show's the same ..7PSI... (yes stock i know..) So i guess I'm not.
As posted earlier doing a rough run in in the garage showed the brass thingy to push down further during boost pressure....(vacume change i guess)
Eventually when i get an exhaust and stuff fitted ill get a dyno tune, and they can check all that for me...
Cheers
Loz
https://www.sau.com.au/forums/topic/13401-blow-off-valves/#findComment-263371
Guest SXU29T
ive had three blow of valves in my s15 since i bought it blitz super sonic s1, then a apexi dual chamber and how a blitz super sonic s2 i found that even though the s1 blitz was 2nd hand from japan of a s13 silvia their was no idleing probs or boost leak and had and awsome bark goes to show theirs nothing like japanese engineering!!! i have a friend who had a brand new gfb bov installed in his skyline it shit itself after bought 13000k's the piston jus kept seizin?//// then swapped my blitz s1 for the apexi dual chamber it was good but didnt really find its sound loud enough(riceboy) and it was a big& bulky mfuca in my engine bay, now i have a blitz s2 its awsome has a diff sound to s1 not as loud but fluters a high boost cause of the fluted design of the outlet. i can give u a contact of some one that can get u a genuine blitz mounting adapter for skylines for bout 30-40 bucks but his in sydney? and its 2nd hand?
https://www.sau.com.au/forums/topic/13401-blow-off-valves/#findComment-289894
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
