First of all Welcome to SAU...
Both these oils are one of the best on the market, however Red Line in my opinion and the opinion of other mech/tuners I have spoken to, is over priced and not nearly as good as RP...
I just bought a 5L jug of RP 10W40 for my oil change and have found them at the following outlets:
Peps Auto - $75
Autobarn - $89 (will price match)
Click on this URL to direct you to the RP Distributor list Australia wide...
http://www.royalpurple.com.au/html/s04_ser...ices&dsb=25
P.S for future references, use the search button cause there is HEAPS of info already discussed on this site... ENJOY!
Regards,
Sarkis
Edited by QRI05E
Your onto the hi end synthetics there >_<. I run the Redline System right through and it has been Excellent. Car runs slightly lower temps under same conditions.
At about 135 dollars from Bursons for 5 litres because of odd size imperial packaging you need to think about it though.
For a skyline you need 1 x 4litre pack and a 1 x 1 litre pack.
Hi Bro,
I know I could get Redline from burson for about $27.00/quart. Me find it rather expensive, so trying to find out from experience forumers if they knew of any other supplier that could supply at a lower price, or the lowest price. Tryin to get a bang for my bucks.
Thank you for your feedback & help. Cheers !
Peps Auto - $75
Regards,
Sarkis
Its only selected Autobarns... however you can get RP from the following in Vic
Eagle Auto Spares
92 South Gippsland Hwy
DANDENONG
03 9793 5544
Sanmateo Performance Systems
19-21 Ninth Street
MILDURA
03 5023 7559
Cheers,
Sarkis
redline is a better oil than royal purple it is composed of a more expensive base which partially explains its more expensive price. it is the best oil you can buy. search for the goods on oils thread for more info, but i would say that you can get a similar performance oil to royal purple for less money.
HOw about Kendall Racing oil? It is made from pure Pensylvanian Crude and is one of the best oils around. There is actually a warning on the packaging stating that it must not be used to run an engine in as the engine wont run in due to the oil having such good lubricating properties.
Kendall is made by Conoco, pretty cheap and good. Mostly group III oil though.
Ok guys... this morning i put some Royal Purple 10W40 with a new cooper oil filter and this is what i have noticed after 100km/s of driving:
- Car idles MUCH smoother and quieter than when using Castrol R and Nuon (comparing to when oil was first changed with both brands)
- Car warms up much quicker on cold starts than before
- Car starts quicker and easier
- Exhaust note on idle is more deep and is not lumpy/poppy anymore
- Acceleration feels 100 times smoother and responsive than Casrtol R and Nulon
In conclusion, I recommend RP for any RB motor.. over any other oil i have ever used!
ROYAL PURPLE
A+++
Regards,
Sarkis
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
