Does anybody knows how to get into contact with nengun? aother than emails. Its been 2 weeks a few emails but no replies IMtrying to purchase powerfc and a boost controller. THanks people
They are slow, but they will get to you eventually, they are not set up to answer questions, especially technical ones. They are simply a reseller, they don't really have stock, they just source whatever you order, once you have paid for it.
Personally I never bother emailing them with questions. I just order what I want, pay the money and it always turns up.
:laugh: cheers :)
https://www.sau.com.au/forums/topic/134460-nengun/#findComment-2499394
:O cheers :sick:
if thats the case for me which one of the power Fc should i order w/ hand controller and the boost controller? BCNr32,33,34? for my 260rs Let me know thanks
https://www.sau.com.au/forums/topic/134460-nengun/#findComment-2499509
im 99% sure 32 and 33 use the same ones from memory. u would need a r33 gtr one, as the 260rs's use r33 gtr running gear :sick: best to get a few opinions as im not 110% sure :O
https://www.sau.com.au/forums/topic/134460-nengun/#findComment-2499530
im 99% sure 32 and 33 use the same ones from memory. u would need a r33 gtr one, as the 260rs's use r33 gtr running gear :O best to get a few opinions as im not 110% sure :O
yeah I said via msn Im 99.95 % sure Yudi needs the R33 GTR Powerfc
Im positive the 260RS for 1997 and 1998 and 1999 etc were based on the R33 and N0T the R34, like how the Series 1 RS4 is based on mainly :O the R33 GTs-T, and unlike the Series 2 RS4 which has components based on the R34 GT-T.
if it was me - Id ask a few questions to ppl on this great forum, and order the R33 GTR PowerFC............ she'll eventually crank over :sick:
https://www.sau.com.au/forums/topic/134460-nengun/#findComment-2499628
if it was me - Id ask a few questions to ppl on this great forum, and order the R33 GTR PowerFC............ she'll eventually crank over :O
:sick: eventually crank over. yea i pmed RBNT for it. so... waiting.
What will i do without this forum :O
https://www.sau.com.au/forums/topic/134460-nengun/#findComment-2499710
ok guys BCNR33 is the code for R33GTR? if so i got it right? Then bosst controller theres a few models to choose in Nengun website which ones? They all say to suit power Fc!!! but theres different codes for each ones
415-A001
AU $ 351.91
AU $ 388.83
To Suit PowerFC
415-A002
AU $ 351.91
AU $ 388.83
To Suit PowerFC
415-A003
AU $ 351.91
AU $ 388.83
To Suit PowerFC
415-A008
AU $ 351.91
AU $ 388.83
To Suit PowerFC
415-A013
AU $ 351.91
AU $ 388.83
To Suit PowerFC
G73GK-TK126
AU $ 351.91
AU $ 388.83
To Suit PFC SW20 Verson 1
let me know guys
https://www.sau.com.au/forums/topic/134460-nengun/#findComment-2500532
Heres some info for ya'all :)
The R32 GTR(BNR32) and R33 GTR(BCNR33) use the same PFC.
The 260RS uses the same PFC as the R32/33 GTR.
The boost control kit to suit this PFC is part#415-A001.
Honestly, Nengun are cheap but slow. Expect to wait about 3-5 weeks for your order.
Greenline are a bit dearer but a bit quicker. Expect to wait about 2-3 weeks for your order.
I can do the same deal for $1400 delivered within 5-10 days.
Thought there'd be some SAU members showing a bit of support for SAU traders :(
https://www.sau.com.au/forums/topic/134460-nengun/#findComment-2500681
support is good performance wise but sometimes money talks :( i know u do it legit with taxes and gst, but people want the most goods for the least money even if they have to wait.
i'd pay another $100 for the quick delivery, but no more or i'd just goto greenline.jp
sorry PW just saying it like it is... no offence to your prices etc as they seem very reasonable for an australian business :)
https://www.sau.com.au/forums/topic/134460-nengun/#findComment-2500870
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
