RPM Performance - Sat' 31st May Drag Day - post here if intending to enter
As you can all see from the thread title change - Ivan has booked us in for Sat' 31st May. It was the first weekend in May AIR had available!
Pricing will follow soon. Naturally the more cars the cheaper it'll be. If the 31st is wet then we'll re-schedule to the following weekend & so on... Hopefully all will still be able to attend if the date has to change due weather.
  • Replies 111
Nightcrawler, thanx for the forum web address. Must say I've been browsing Skyline web sites for awhile and never come across this one so I'm stoked. What time did you end up running?? Also, you'll have to drop me a line next time you guys go for a cruise.
Munro - i wish it was me in that bracket, I've never got to see a good view of your runs, what with the constant line up. A run next to a 9 second car, at least for the first 60 feet would be awesome!!
32godzilla .... my best run was the first one - a 13.41 @ 104.5mph - 1.932 60' .... the other 2 runs I missed second gear on both :) for 13.816 (to beat a thumping V8 Commodore :) ) & 13.914
For videos of 2 of my runs and 2 of Munros (incl. the Aus record run) go to: http://briefcase.yahoo.com/bc/andnus2002/l...rc=bc%26.view=l for downloads (sorry about the sizes of the files). Enjoy
Yeah Matt the vids came out pretty well. I loved my launches but was sorry to see you bog down ;) .... you definitely need some :burnout: on your launch!!!
The vids also show how much you pull on me top end - I still can't for the life of me figure out why that is so????
Just goes to show I need to get a cooler in before the drag day :) :shake:
tN^,
I'll put you down on the list I'm keeping mate. Anthony & another GSR/EVO club member are already on it. Ivan is keeping me informed of ALL entries so my list stays up to date.
Cheers,
Matt
Just a thought - has anyone organized a tow truck or recovery vehicle?
might come in handy at some stage, especially with 50 odd cars.
I reckon it would be hard work pushing a car back from right down the end:D
Chris,
I'll add that to the list of things to ask AIR about. They "should" have a vehicle for recovery as part of the track hire fee!?
grepin has volunteered to use his R33 as the tow/recovery vehicle.
As you may recall it's been specifically tuned for that purpose, that Power FC and OS Giken Twin Plate Clutch combo will finally be put to good use.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
