Hi people,
I have a Genuine Japanese Katana Sword for sale.
Picture tells all.
Hasnt been used on anyone yet (LOL :D )
Very nice for display in the house.
Comes with display stand.
$200 ONO (RRP $290)
This Item is now Sold.
Thanks for everyones interest.
Its a good Sword, and now its in an even Beta Home.
MAD
Thats why they call me Happy Gabby
Edited by happygabby
https://www.sau.com.au/forums/topic/134640-sold/
Thanks for everyones interest, but this has been in my Garage for a long time,
its still new and the blade its still the same as is was when i got it.
I do have certifs for it, but my garage is so full of SH*T that it will take me forever to find it.
But i can Guarantee that it is Original and its in Awsome Nik.
Unfortunatly for people that are interstate, i wont be able to post, well not unless you want to get done for this "DEVINE" work.
i will take photos of the blade, will be on there in 20 mins
https://www.sau.com.au/forums/topic/134640-sold/#findComment-2503003
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
