I want to do a complete replacement of my brake fluid but i have some questions for the experts;
1. Do i just pump it all through with the pedal after replacing the fluid in the resevoir?
2. How will i know when all the old stuff is out (and how much will i need for R32 GTR)?
3. Does the ABS unit need any attention?
4. Is it ok to use high temperature fluid (Motul 600) in a car that does the occasional track day but is mostly street driven?
Cheers,
Kot
What I've been told:
DO NOT pump it through. Jack the car up on all four corners. Simply open the bleed nipples and let the fluid drain under gravity
When the fluid stops flowing, top up the reservoir, and let the new fluid flow through under gravity. Helps if you use different coloured fluid, otherwise you have to basically guess. Close off all the nipples, then do the normal brake bleed method.
Nothing out of the ordinary.
The temperature resistance of the brake fluid can't be too high, ie high temp fluid is better than lesser temp fluid.
If you simply pump the pedal you will suck air back in as you release it.
The only way to pump fluid through is in this sequence:
1) open bleed nipple
2) push pedal 2/3 of the way to the floor (NOT all the way you can root your master cylinder seals if you do)
3) hold pedal at that point
4) close bleed nipple
5) release pedal
repeat. obviously you need 1 person working the pedal and 1 person opening and closing the bleed nipple.
a simple gravity bleed is much simpler you just jack the car up evenly, whack a bleed hose on and open the nipple, then wait until you see new brake fluid (you'd want it to be different colour to the old stuff).
start from the corner furthest away from the master cylinder (ie the rear left) then the next closest (rear right) then left front then right front last.
I would always do a gravity bleed unless there was a reason why that didn't work, or i was in a hurry and had extra help available.
Edited by Kinks
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
