*******big Aquarium And Cabinet********sold
Guys I have for sale an aquarium
Tank: 5ftx1ftx2.5ft with glass lids all 10mm and a 12mm base [rrp $1000.00]
Cabinet : 5ft raw timber with 3doors [rrp $600.00]
Hood: 5ft raw timber [rrp $200.00]
Filter: Fluval 404 canister filter (brand new) [rrp $350.00]
Light: 4ft light ballast (brand new) [rrp $65.00]
Heater
Power head (for water circulation)
Gravel: 20kg coral sand [$60.00]
15kg of Live rock [$200.00]
1 clown fish
4 chromis damsels
Im located in sydney and it will be pick up only, its a massive tank!!!
Asking $999 for the lot! SOLD
Absolute bargin!!!!
Serious buyers only please.
0420560838
located near parramatta.
https://www.sau.com.au/forums/topic/134762-big-aquarium-and-cabinetsold/
  • 5 months later...
My 4x2x2 came with a 15mm base.
And???
look mate Im selling and your obviously not buying so please go and find something else better to do then bag my sale...
    • ..this is the current state of that port. I appreciate the info help (and the link to the Earls thing @Duncan). Though going by that it seems like 1/4 then BSP'ing it and using a bush may work. I don't know where I'd be remote mounting the pressure sender... to... exactly. I assume the idea here is that any vibration is taken up by the semiflexible/flexible hose itself instead of it leveraging against the block directly. I want to believe a stronger, steel bush/adapter would work, but I don't know if that is engineeringly sound or just wishful thinking given the stupendous implications of a leak/failure in this spot. What are the real world risks of dissimilar metals here? It's a 6061 Aluminum block, and I'm talking brass or steel or SS adapters/things.
    • And if you have to drill the oil block, then just drill it for 1/4" and tap it BSP and get a 1/8 to 1/4 BSP bush. The Nissan sender will go straight in and the bush will suit the newly tapped hole. And it will be real strong, to boot.
    • No it doesn't. It just needs an ezy-out to pull that broken bit of alloy out of the hole and presto chango - it will be back to being a 1/8" hole tapped NPT. as per @MBS206 recco. That would be for making what you had in alloy, in steel. If you wanted to do just that instead of remote mounting like @Duncan and I have been pushing. A steel fitting would be unbreakable (compared to that tragically skinny little alloy adapter). But remote mounting would almost certainly be 10x better. Small engineering shops abound all over the place. A lathe and 10 minutes of time = 2x six packs.
