Some parts that where going or used in my r32 GTR no longer needed.
1) R32 GTR fuel pump with strainer, replaced with bigger pump - $100 perfect condition $80
2) New hi filled R32 GTST after market side skirts Mspec style - $180 ONO needs to go
3) Stock R32 GTR skirts - $50 gunmetal grey
4) Apexi Exhaust Control Valve with flanges, approx 6inchs long 3inch pipe - $100
New parts added -
6) HKS POD filters x 2..suit z32 AFM filter elements only done approx 8k asking $100...note one of the top screws was replaced with different screw to hold down the metal mesh.
Parts just laying around doing nothing!
https://www.sau.com.au/forums/topic/134836-r32-parts/
AM putting these parts up again as cant find my other ad?? anyways here are some parts available and in sydney.
1) UsedR32 GTR fuel pump - $100 up on sale again cos of time waster.
2) New hi filled R32 GTR after market side skirts - $280
3) Stock R32 GTR skirts - $80 gunmetal grey
4) Brand new Drift Race seat with carbon back - $550
5) 2x17inch tyres Dunlop 300 235x45 99% tread - $250
6) Used hi flow cat around 10K - $70
Prefer Sydney pick up as some items are big but for pump/cat can send anywhere.
Hi
I'm interested in the larger skirts - but I'm in Brissy - let me know if you will ship
https://www.sau.com.au/forums/topic/134836-r32-parts/#findComment-2506276
  • 5 weeks later...
  • 4 weeks later...
  • 3 weeks later...
2) New hi filled R32 GTR after market side skirts Mspec style - $180 ONO needs to go
New parts added -
bump new prices
https://www.sau.com.au/forums/topic/134836-r32-parts/#findComment-2778697
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
