any ideas as to why an r33 auto trans would only select 2nd gear when in drive, have no kick down funtion and feel like an almost burn't out clutch?? these are the symptoms my car has, but there only every once and a while, take today car has been doing this since tuesday morning today it started doing this then after i had stopped at a servo it went back to normal driving mode, then while driving it went back into 2nd byitself and stayed there...
any ideas as to what part of the transmission might cause this problem? its a wiring issue i'd say but what part...
Cheers, Matt...
https://www.sau.com.au/forums/topic/135047-r33-auto-issues/
Does it go back to normal if you turn the car off completely and restart it?
Mine would occasionally do this but go to 3rd gear. A 'reboot' fixed it every time.
it has fixed itself again, but no i would turn the car off and then when i had to drive again it was still there, in the end i parked at my GF's work to pick her up, i parked on a hill with the front of the car facing down and then 10 min's later when we left it was back in normal drive mode?? i'm thinking there was no trans fluid in the torque convertor?? thats all i can think of..
cheers for the reply..
Edited by rsx84
https://www.sau.com.au/forums/topic/135047-r33-auto-issues/#findComment-2533684
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
    • Yeah - I mean, go the other way. Smaller range. Not larger.
    • To re-cap, I bought: https://www.alibaba.com/product-detail/Lsailt-8G-Infiniti-Q50-Q60-2014_1601171829627.html?spm=a2756.trade-list-buyer.0.0.2cd476e9FTIlKE As you can see, if I bought 20 it was $653, but I bought 1 so it was $1,170. I was very tempted to buy 2 and resell 1 at 25% cheaper. @MBS206, I am not sure if they do a Kluger one, here is their list but it might be there under a global model name: http://www.lsailt.com/product/android-interface?page=1 Keep in mind these full android replacements have basically all the bits a phone does (cpu, ram, storage, wifi, bluetooth, usb interfaces) other than a screen (it uses a host), thus the $800+ cost. Android Auto screen mirroring is MUCH cheaper as it's just a cut down shell, input mirroring and output mirroring BTW I also need that "screen off" feature, it is much harder to see wildlife even if a dash is reasonably dark. Both the Fuga and V37 have display off buttons for night use, they just come back on for a second or 3 if you interact with it, eg skip a song.
