Hey guys,
I have an RB25DET w/ the RB25 tranny all swapped into my R32. Clutch is an ATS twin plate carbon.
A month ago my pedal started to make a squeeking noise every time i pressed the clutch down, and when it let it back up.
Last week, my clutch pedal bracket snapped while driving! I brought it to my guys' shop and the fixed it. Welded it back together and reinforced the s$%t out of it.
It was quite an easy fix, put it back in and cha-ching! It's working again.
A few days later, the squeeking noise came back. Now my main concern right now is that the squeeking noise is associated with the bracket breaking. Would that be true????
Or is the noise just from the stress of having a heavy twin plate ATS clutch??
[edit]
Oh, i forgot to mention i am not talking about the plates chattering.
It's actually noise coming from the pedal.
IE// if you have the car off and step on the clutch pedal, it would make a creeking / squeeking noise.
Edited by 604cefiro
i have a similar problem. Nismo single plate strengthened push type clutch cover, rb25det, 4wd. A few days ago the pedal begin to produce a squeeking/creekingsound especially after warm-up.
i don`t have a solution yet.
I also have the same problem but on my RB20DET gearbox. I believe it is one of the thrust or spigot bearings in the gearbox (mine is the spigot because it only creaks when u move the pedal) whereas if its when the clutch pedal is released and ur not touching it, then it is usually the thrust bearing. Not Sure tho....Any experts care to help me ouut here?
Not much help but I had he same prob. Mangled the crap out of the bracket and then bought another one and went crazy with the welder. Mine before and even after the bracket episode makes a squeaking sound.
Clutch is an Ogura twin with a very heavy pedal.
Same issue different sort of car, as bob said try wd40 on the pivot point that usually does help but does usually come back after wd40 wears out
    • No. BSP lost to the cultural/technical imperialism of living next to Trumpistan. Face it, Robertson screws were better and still pretty much lost out to the yank stuff. The Europeans hate the Brits and they don't use NPT. NPT is just as "imperial" as BSP is, being based on those useless inch thingos. Just done differently.
    • I live in Quebec. Our license plate slogan is "Je me souviens" Translated is "We will remember" as a reminder to when England conquered us and that we must never forget what they did. Long story short, BSP is unheard of here due to being an English design. I'm surprised our nazi anti english government office the OQLF hasn't kicked in my door yet just talking about it, yet alone imperial anything.
    • Thanks for that! I did a quick Google search looked up some of hydaulic stores and didn't see it listed on the website, I'll give them a ring. Also found out later that I can buy 2 oem bleeder bolts for 10 bux and come with the washer which I might do so I don't waste the money it costs in petrol to find 2 washers (already did that lol). The old copper washes look in good nick, I drove it after taking it off and putting it back on and didn't see any  Part number here for reference if anyone needs: 14053-42L0A
    • Piggaz had one and broke it at 470kw
