Hey guys I purchased a GFB Boost control yesterday and am yet to master how to install :lol:
Is this correct because my boost is staying the same (7psi) and I am hearing a hissing sound which the instructions say means it isnt tapping a boost line? I'm a bit confused now on what ive done wrong if anyone can help it would be appreciated?
Cheers, Tim
https://www.sau.com.au/forums/topic/135482-gfb-atomic-boost-controller-help/
The hose to the waste gate actuator on the turbo is right but is the other end T'ee peiced into ur canister line?? it should go directly to a nipple on one of hte intake pipes, looks like u have a aftermarket pipe which mihgt not have it , basically it needs to be in a presurised section o fhte pipe work. the boost controler bleeds air to make the waste gate actuator htink there is less pressur and not opening hte waste gate allowing u to make more boost.
Yeah Its around the right way -> facing the wastegate actuator and yeah I've noticed that my intercooler kit doesnt have a nipple :rolleyes: its a Monkey warehouse kit too, is there any way around this that anyone knows of?
damn thos pics are small .. bigger ones?
arrow faces the wastegate actuator.
line needs to come from the plenum or the IC piping..
looks like it is trying to use the line from the plenum to the carbon canister
should be direct line -- plenum - boost controller -- actuator
    • Hi all, Long time since I've posted here. Looking for some advice on what I can remove to further identify the cause of my issues.  I can move the passenger seat forward and back but the knob used to adjust the seat angle is pretty much free spinning, there's very little resistance.  Removing the side cover I can see that the chain is intact but the shaft for the adjustment spins without the gear attached to it moving.  What's my next step for disassembly here? Is this a common fault? Just being a little cautious as I didn't want to start removing bolts for a spring to fly out or something equally as stupid.  Cheers
    • Those above shitboxes, mediocre and above usually have a turbo strapped to them, hence the slightly higher octane is required.
    • Hi all,   long time listener, first time caller   i was wondering if anyone can help me identify a transistor on the climate control unit board that decided to fry itself   I've circled it in the attached photo   any help would be appreciated
    • I mean, I got two VASS engineers to refuse to cert my own coilovers stating those very laws. Appendix B makes it pretty clear what it considers 'Variable Suspension' to be. In my lived experience they can't certify something that isn't actually in the list as something that requires certification. In the VASS engineering checklist they have to complete (LS3/NCOP11) and sign on there is nothing there. All the references inside NCOP11 state that if it's variable by the driver that height needs to maintain 100mm while the car is in motion. It states the car is lowered lowering blocks and other types of things are acceptable. Dialling out a shock is about as 'user adjustable' as changing any other suspension component lol. I wanted to have it signed off to dissuade HWP and RWC testers to state the suspension is legal to avoid having this discussion with them. The real problem is that Police and RWC/Pink/Blue slip people will say it needs engineering, and the engineers will state it doesn't need engineering. It is hugely irritating when aforementioned people get all "i know the rules mate feck off" when they don't, and the actual engineers are pleasant as all hell and do know the rules. Cars failing RWC for things that aren't listed in the RWC requirements is another thing here entirely!
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
