I just finished running the new motor in on the dyno and did a base tune
The vehicle has undergone alot of Development now
Engine
Nitrated R33 GTR crank
H beam Eagle Rods
Venoila 9.2 Comp Pistons
Tommie Head Gasket
Solid Lifter Conversion
Big cams
GT 1100 hp bb turbo
2 speed powerglide
2 stage single sprayer nos kits
It has made 485 rwhp on 10 psi @8500rpm
I will post the Dyno sheet on 2morrow with the run on 30 psi
hopefully make around 800 rwhp
I should be at the track in the next 2 weeks
I will also post picts with photos of the new engine bay and if someone can host a video clip ill appreciate it
Edited by MR331307
https://www.sau.com.au/forums/topic/135859-lnemup/
  • Replies 51
Posted Images
Hello everyone
I just did a safe tune on the vehicle and it made a total of 648 rwhp @ 30 psi on a 10.2 AFR
I am going to do some more Tuning on it to get it to 720 or so RWHP But im waiting on a MSD dis 4 before i can run more boost and before i start bumping up the timing.ill hit the track next wenesday night.Aiming in the 9`s somewhere
Hopefully towards the end of the year i can run in the high 8 area,
I havent installed the CHUTE yet but i will after i get back on wenesday.
ILL post up some Dyno Picts and Videos soon3
Its still the RB25 Block just with GTR crank,Eagle Rods,Venoila 9.2 comp Pistons.
The car makes power to 9000rpm which will be fun at the track
When everyone sees us up there come up and say hello
Edited by MR331307
https://www.sau.com.au/forums/topic/135859-lnemup/#findComment-2542799
around 6300 without nitrous
but i got nitrous on till 18 psi so i can gety on boost quickly and it gets on boost around 5700
Ive had lnemup plates for around 4 years
and the venoila pistons are pretty good quailty so i shouldnt have a problem
Edited by MR331307
https://www.sau.com.au/forums/topic/135859-lnemup/#findComment-2544094
    • planning a r34 rb25 de+t with some other work, rather just have it done in a shop due to space limitations any recommendations? I have most the parts already I seen online Moore Performance and DR Drift any advice appreciated thanks
    • I’ve read the previous posts so just looking for latest information on how people have dealt with front facing plenum is it a defect etc or didn’t pass roadworthy or was it not noticed? Have a r34 and deciding if I should make a hole on the driver side or not.  I know some people have said blitz return flow but I might get rid of the stock intake down the line for a plenum so I rather set up for that now plus I already have a standard Intercooler. Car is mainly stock  Thanks.
    • Actually, if having and keeping the stock ECU is the plan, the correct answer is to put Nistune into the ECU and improve the situation, not just look at it.
    • Wrong side of sydney for me coming from Goulburn, but you should head along, all ages of Skylines will be very welcome
    • Yeah so physically that port is consult not OBD2, but also be aware that "JODB" is not really a thing - it came in around 2000(ish) but is not a standard like ODB is, each manufacturer had differences. If you are looking at ECU only and have a standard ECU, go with Datascan as Turbo Tapin said. Per another recent discussion here thought that won't do other systems like in a modern car, for example bleeding ABS
