I just finished running the new motor in on the dyno and did a base tune
The vehicle has undergone alot of Development now
Engine
Nitrated R33 GTR crank
H beam Eagle Rods
Venoila 9.2 Comp Pistons
Tommie Head Gasket
Solid Lifter Conversion
Big cams
GT 1100 hp bb turbo
2 speed powerglide
2 stage single sprayer nos kits
It has made 485 rwhp on 10 psi @8500rpm
I will post the Dyno sheet on 2morrow with the run on 30 psi
hopefully make around 800 rwhp
I should be at the track in the next 2 weeks
I will also post picts with photos of the new engine bay and if someone can host a video clip ill appreciate it
Edited by MR331307
https://www.sau.com.au/forums/topic/135859-lnemup/
  • Replies 51
Posted Images
Hello everyone
I just did a safe tune on the vehicle and it made a total of 648 rwhp @ 30 psi on a 10.2 AFR
I am going to do some more Tuning on it to get it to 720 or so RWHP But im waiting on a MSD dis 4 before i can run more boost and before i start bumping up the timing.ill hit the track next wenesday night.Aiming in the 9`s somewhere
Hopefully towards the end of the year i can run in the high 8 area,
I havent installed the CHUTE yet but i will after i get back on wenesday.
ILL post up some Dyno Picts and Videos soon3
Its still the RB25 Block just with GTR crank,Eagle Rods,Venoila 9.2 comp Pistons.
The car makes power to 9000rpm which will be fun at the track
When everyone sees us up there come up and say hello
Edited by MR331307
https://www.sau.com.au/forums/topic/135859-lnemup/#findComment-2542799
around 6300 without nitrous
but i got nitrous on till 18 psi so i can gety on boost quickly and it gets on boost around 5700
Ive had lnemup plates for around 4 years
and the venoila pistons are pretty good quailty so i shouldnt have a problem
Edited by MR331307
https://www.sau.com.au/forums/topic/135859-lnemup/#findComment-2544094
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
