  • Replies 51
Posted Images
well i went to run done a big burnout and the oil return off the turbo melted.We fixed it went back out and they didnt let me run cause the car is toooooo Loud even though they teched it like that.Anyways
the other offical told me to come back next week so i packed up.
And then on the way home we smashed into a car they pulled out in front of us and just got out of hospital
pretty bad night
Ahhhh well
Have to wait for next week
did anyone get any video of the burnout
https://www.sau.com.au/forums/topic/135859-lnemup/page/2/#findComment-2556928
pretty bad night
Ahhhh well
sorry to hear that mate.. all the best next week
https://www.sau.com.au/forums/topic/135859-lnemup/page/2/#findComment-2557291
Ahhhh Jason thats a shame buddy, as long as your alright thats the main thing... unfortunalty i missed your burnout.. i will go next week if your running... Take care bubby! Cheers
Edited by QRI05E
https://www.sau.com.au/forums/topic/135859-lnemup/page/2/#findComment-2557902
Is the tow vehicle very broken?
Now what kind of a remark is that adrian
And i wasnt towing the car my dad and his friend was
i was in another car that crashed and yeah the cars f**ked
engine ended up under mine and my brothers feet
https://www.sau.com.au/forums/topic/135859-lnemup/page/2/#findComment-2558328
What kind of a remark is it? Sorry, I assumed you guys were in the tow car. Simple question, mate. Stop reading more into it than there is.
Glad you guys are ok.
https://www.sau.com.au/forums/topic/135859-lnemup/page/2/#findComment-2559337
Probably can expect to have the car on the trailer often if you continue to rape it in the burnout like that.
looking fotward to a clean pass.
pretty bad night
Ahhhh well
https://www.sau.com.au/forums/topic/135859-lnemup/page/2/#findComment-2559402
What size slicks are they Jase? They look huge but I'm sure it's just the angle.
Cheers.
ADRIAN
do you have photos of the actually burnout
and
yeah if Some COCK head didnt complain about the noise and say i took my exhaust off maybe i would have raced.Some jealous c**ts out there isnt there
anyways i will be out next week and have to see what happens
https://www.sau.com.au/forums/topic/135859-lnemup/page/2/#findComment-2562253
the only problem i had was a Return pipe flange gasket
ahghh welll
anyways have to see what she does when im out there next
ill be interested to see what your car makes and runs.why is it your a smart ass behind a computer
https://www.sau.com.au/forums/topic/135859-lnemup/page/2/#findComment-2562260
ahghh welll
I only said the above because I know what it's like, mate. No need to take it so personally and go on the attack. I don't understand why you go on the ofensive all the time. I've been there and done that with a number of cars and if you start making power and raping them you're gonna hurt them from time to time. abusing them will only increase the chance of some type of failure. your burnout was as you would probably agree stupid. if you had done a solid burnout instead of the exibition style one you did, you probably would have been able to run.
Edited by BezerkR32
https://www.sau.com.au/forums/topic/135859-lnemup/page/2/#findComment-2563032
Haha. dont read more into it than there is, besides they specialise in fabrication where we specialise in mechanical so you cant really compare the two. They are good at what they do and so are we.
WWW wollongong workshop warz
Round 1 coming soon to WSID
contact BU5TER for tickets and program
https://www.sau.com.au/forums/topic/135859-lnemup/page/2/#findComment-2566623
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
