Please remember, everyone, we want genuine ideas and suggestions here. We are slowly trying to help the club grow, and funds are tight. The more people we can attract towards signing up as SAU-NSW club members, the better our situation will be! And those people who sign on as members will reap the rewards of cheaper merchandise, as well as all the other benefits of club membership, as outlined here. The problem with some items is that there are minimum runs that we will have to buy before we can even consider them. One example are the thermal travel mugs, where the minimum product run is 100 - will we be able to sell this many travel mugs, or are they going to sit on the shelves of the SAU-NSW stock room and collect dust (not to mention the money wasted on a non-selling item).
Regardless, all ideas are welcome, and time will tell how viable each suggestion becomes!
As above...
  • Replies 155
Hmmm, not sure the sunglasses would be a realistic and/or viable option to do, but I'll add it to the list.
I didn't know how viable they'd be, as yeah, sunglasses are a bit of a hard market to cover for.
Does anyone have a link to the already available merchandise?
what about getting copy china intercoolers and putting sau logo on them, i suppose youd have to have neough interest to order enough to make somre profit, or even just not to have them sit there as mentioned, but there are a lot of people who want intercoolers, but china copies and im sure wouldnt mind having SAU logo on
The link to the current range of merchandise is here...
Please note, though, you need to be a current SAU-NSW member to view the link as these goodies are currently only available to members. We are looking to change this in the near future.
Once we figure out what products we will be offering to everyone, we'll most likely post pics of samples of the goodies we'll be offering.
Goldzilla, I'm not yet a member, but I will be joining very soon, I just need a couple of spare $$$ (Currently owing sister some money, plus christmas etc coming up.)
Cool, all new memberships are VERY welcome.
The more members we can get on board, the more the club can afford to give back to members...
And of course, all of the new products offered will be cheaper to club members!!!
gday im a new member and i just thought that if you guys want i can find out how much i can get a bulk order of stickers for due to i know someone that is a sign wrighter and i think that the sun shield is a good idea and to go with that what about a steering wheel cover and gearknob caver for the hot daysto protect them from the sun.
Made some enquiries today about the gear knob covers, and no-one I know has seen one or knows where to get one, unfortunately.
Sun visors/heat shields for the front windscreen are currently being researched further, as are the stubby holders/beer coolers. Also looking at steering wheel covers as an alternative to the full windscreen sun visors, we'll see what happens...
:P
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
