Front lip is being respayed soon
54 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
If respray doesnt bother you, get it black, see if your like it, if not respray it back to white ;)
well...I say it doesn't bother me an it doesnt cost that much.....but still not something i want to do from week to week....aint that cheap....hehe :D. Once a year to keep the car looking decent is enough.
when I had mine done originally a few years back it cost me $60 per rim including sandblasting, I took the rims in to them in the morning and picked them up that same afternoon. Coating places wont do the work for you, there not mechanics and dont have tyre machines, so you'll need to organise taking them off your car, getting the tyres stripped off at your local tyre shop as well as removing the valves an any wheel weights, then take the rims to them as bare rims.
Hope thats of some help. Cheers
Yep sure did, cos i want my rims resprayed, so now i know they have to be butt naked.
NismoR32 (who's R32 took out best R32 in the SAU VIC show n shine) had a factory black lip on his white GTR. It look teh hotness.
plus its easy to fix with some bumper black when you run shit over.
my rims are all naked an being sandblasted tomorrow, powdercoated tues/wed, an should be picking them up thursday arvo. Just in time to get tyres fitted an have them back on my car friday ready for the drag day Saturday...;)
so i'll have black rims for first half of the day, then i'll crack out my MT drag radials that are on my hot pink AVS 16" rims on the rear of my car for the second half...lol
my rims are all naked an being sandblasted tomorrow, powdercoated tues/wed, an should be picking them up thursday arvo. Just in time to get tyres fitted an have them back on my car friday ready for the drag day Saturday...:D
Let me know how much it set ya back all up sandblast and powdercoat..
thanks mate..
Wayne: What I'm paying isnt what it'd cost....as I'm getting it done through a freind of a friend sorta situation that will be doing it afterhours. I'd assume it's cost about $200-$250 to get 4 rims done, the coating costs about $100 for 4 rims, uncertain about sandblasting costs though.
thanks for the pic JNR747. I dont mind the look of the black lip, but still leaning more towards sticking with white. It's being done in a weeks time so best I make my mind up quick smart.
thanks for all the respose so far guys, always appretiated
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
